HOT no start issue with Honda Civic
I need YOUR help as American Honda.
For 3-5 years, our Honda Civic does NOT start for 2 minutes - 60 minutes when it is HOT outside. It does NOT crank. It acts like it has a DEAD battery, except the battery is OK and the windows work.
We tried using a NEW key which worked and now we have the same problem of the Honda Civic NOT starting when it is HOT outside.
I have researched the HOT NON START issue on the Internet and there are 1000's of articles and examples of this issue with Honda Civics
I am POSITIVE Honda knows of any the HOT weather affecting the Honda Civic to NOT START for 2-60 minutes.
I NEED YOUR HELP to FIX MY Honda Civic in Austin Texas
Thank you, Jeff
Thank you, Jeff
i would start by testing the battery voltage....higher then 12v?
next i would disconnect the battery and clean the terminals and battery leads with a mixture of baking soda and water, use a wire brush if nessessary,
make sure they are spotless, specifically on the inside of the leads,
make sure everything is clean dry before you reconnect
You've got a car that's almost 15 years old. I need YOUR help as American Honda.
Doesn't sound like a problem for American Honda.
It sounds like you need someone competent in basic electrical diagnosis to figure out the problem, and it probably needs to continue acting up long enough for that person to figure out what the problem is.. It does NOT crank. It acts like it has a DEAD battery,
Do you have an ammeter, a voltmeter, and know how to use them?
Can you perform a voltage drop test?
I do NOT understand that I can see 100's and 1000's of post about a HOT NO START issue for the Honda Civic, BUT NO one knows what the ISSUE is and HOW to solve the ISSUE
It's Top Secret
Quote:
But we're cleared and we have a need to know....Originally Posted by ezone
It's Top Secret Quote:
OP is not, so I left you a copy of the Top Secret Official Document in the usual rendezvous location. Use your secret decoder ring, the key is scribbled on p42 of the document. Memorize the information then destroy it.
Maybe we should use the cone of slience.... Originally Posted by ezone
Thoughts....Originally Posted by jeffmensch
HOT no start issue with Honda CivicFor 3-5 years, our Honda Civic does NOT start for 2 minutes - 60 minutes when it is HOT outside. It does NOT crank. It acts like it has a DEAD battery, except the battery is OK and the windows work.
1. OP says for "For the last 3 to 5 years"... so I guess this isn't urgent.
2. This site is not affiliated with "American Honda" and I doubt they monitor it. Find the 800 number for them or an email and you can communicate directly with them.
3. It would be best if you answer the question(s) you are asked if you want our help...
Thank you,
Smiley
Quote:
Lighten up Jeff, we are trying to help you. Don't take some kidding around personally.Originally Posted by jeffmensch
You make jokes at my expense, good luck If your car is an stick shift then I have an idea.... but I asked what transmission you have AT or MT and you have not answered....
Based on the posts I've read here, it would seem the OP has little or no intention of figuring out and fixing the car himself, nor is he willing to pay a professional to figure it out and fix it.
Hondas responsibility for fixing the car ended when the warranty ran out.
You own the car now, that means you are responsible for the maintenance and repair of it.
Main relay?
[URL=https://www.youtube.com/watch?v=X5Qp-ToR8KA[/URL]
OP said no crank....Originally Posted by alex_nyc
Main relay?[URL=https://www.youtube.com/watch?v=X5Qp-ToR8KA[/URL]
ok, no crank.
so would changing the starter or solenoid be a good place to start being its a heat related issue?
lighten up, are you ****** kidding me? what is wrong with you? this is a honda civic forum, NOT comedy stupids!
Quote:
you arn't even bothering to TRY so why expect more help?Originally Posted by jeffmensch
I do NOT understand that I can see 100's and 1000's of post about a HOT NO START issue for the Honda Civic, BUT NO one knows what the ISSUE is and HOW to solve the ISSUE did you even TRY my original suggestion?
I am expecting NOTHING from comedians who I thought were professionals
Quote:
you get what you pay for Originally Posted by jeffmensch
I am expecting NOTHING from comedians who I thought were professionals why don't you go and PAY a professional then?
Quote:
If you would like to pay for my flight, lodging, food and labor time plus any needed parts; then I could be the pro you are looking for. (labor fee $150 per hour)Originally Posted by jeffmensch
I am expecting NOTHING from comedians who I thought were "professionals" Other wise we can try to help you if you start testing the systems we are asking for and answering the questions (because this is all theory and we have no idea what is causing your issue, if you do not explain).
or you can pay a local mechanic
Quote:
I am not a professional, and nobody who posts replies is paid by civicforums. We are all volunteering our time, knowledge & experience to help.Originally Posted by jeffmensch
I am expecting NOTHING from comedians who I thought were professionals I asked a simple question and still you have not answered it. Instead you have more complaints. Nobody here owes you anything. Go address "American Honda" and quit your whining....
My Civic runs great. Everything works as it should and I get good gas mileage. I'll be just fine. You've had the issue 2-3 years, why are you whining about it now?
I seems the OP refuses to be helped by this forum, we don't offer the sort of help he needs.
Maybe he would receive some helpful replies from the kind and professional folks over at this forum (<--link)
Moderators: This thread has been circling the drain for 3 days.
Time to flush the punch bowl?
Moderators: This thread has been circling the drain for 3 days. Time to flush the punch bowl?
Final update, Took car to Honda dealer, Car did not start, Tested starter and replaced starter motor
Quote:
i hope it fixes your problem.....although i am very doubtful.....good luckOriginally Posted by jeffmensch
Final update, Took car to Honda dealer, Car did not start, Tested starter and replaced starter motor Quote:
Thank you, Jeff
HOT no start issue with Honda CivicI need YOUR help as American Honda.
Thank you, Jeff
I do NOT understand that I can see 100's and 1000's of post about a HOT NO START issue for the Honda Civic, BUT NO one knows what the ISSUE is and HOW to solve the ISSUE Quote:
You make jokes at my expense, good luck Quote:
I am expecting NOTHING from comedians who I thought were professionals Quote:
lighten up, are you ****** kidding me? what is wrong with you? this is a honda civic forum, NOT comedy stupids! Quote:
What was so hard about that?Originally Posted by jeffmensch
Final update, Took car to Honda dealer, Car did not start, Tested starter and replaced starter motor Did they do this work for free?
Did you act the same at the dealership, as you did here for us?
Originally Posted by mikey1
you get what you pay for why don't you go and PAY a professional then?
