Squeaky springs?
Old May 12, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Squeaky springs?
YOu got this problem? well this might help
When you springs were installed.. there wsn't enough space left for the compression of the spring... on the strut baseplate there is a notch where the end of the spring supposed to meet but if you put the end of the spring right against it... that might be where the squeak is from.. most installers rust it so the space isn't left for the springs. rotating movement when it is compressed..
i recommend that 1cm or 1/3 of inch is left from the end of the spring before it touches the notch..
Old May 12, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
holly crap that was really technical sorta, i'll have to save this in case i get squeaking
Old May 12, 2002
Kraize2001Civic's Avatar
Kraize2001Civic is an unknown quantity at this point
I didnt know that thanxs Macko for that tip..I am going to install my springs when i get them (still waiting for them to be delivered)..Ill keep that in mind...here's a [IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
Old May 12, 2002
Macko's Avatar
Just lending my knowledge.... after all if i cherish my baby to make sure everything is as perfect as possible, you guys want to do as much as you can to keep it perfect right? isn't that what this forum is about?[IMG]i/expressions/beer_yum.gif[/IMG]
Old May 12, 2002
Yup same here i charish my baby also..
Old May 12, 2002
marlette13's Avatar
marlette13 is an unknown quantity at this point
Real easy way to avoid that problem. I put some of the ajustable coil-overs on, and needless to say they were $150 dollars of crap I now have sitting in my room. They squeaked, and clanked, and I got the pleasure of hearing my car bottom out all the time. Then I got smart. I bought some Sprint Springs for my 2K1 Civic Coupe. I had those put on as well as my Ingalls front camber kit. The car not only rides just as good as the stock spring, is as quiet as ever, but it's perfect height. I can't fit a finger in between the wheel well and the tire in the front or back. Rides great and looks great. Didn't cost that much.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
