DIY: Installing A Plug To Repair A Tire Leak (Video Tutorial)
Old 08-05-2011
ProStreetDriver's Avatar
ProStreetDriver is an unknown quantity at this point
How to install a plug to repair a puncture/hole in the tread face of a tire. The sidewall cannot be repair as it is unsafe and illegal.
Procedure:
-remove tire from vehicle
-find air leak using soapy water and watch for bubbling
-remove object in tire using a screw driver, pliers, etc
-using the reamer from the tire repair kit, stick in the in the hole so it goes through to the other side, twist reamer to clean hole
-load plug into needle, center plug in needle
-stick plug 2/3 length tire with 1/3 left exposed to the outside
-pull needle straight out quickly without twisting
-cut off access plug using side-cutters, razor, etc
-pump up tire and reinspect for leak
-when all is done, reinstall tire on vehicle
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1014& transactionid=1312553560-69633412&posted_by=ProStreetDriver_www.civicforums .com&youtube_video_id=JW6OtOJXtzw[/autostream]
danace99
23
06-28-2015 08:49 AM
bsmiley
04-27-2015 01:27 PM
bo_red
04-23-2015 10:09 PM
CascadiaBlue
04-18-2015 09:13 AM
technosilver
11-14-2001 10:58 AM
Quick Reply: DIY: Installing A Plug To Repair A Tire Leak (Video Tutorial)
