DX to Ex conversion
Old Jul 18, 2011
chesspl8te71's Avatar
chesspl8te71 is an unknown quantity at this point
DX to Ex conversion
Hello everyone new to this board. Looking for some help in switching my Dx over to Ex with the Vtec. I'm not to familiar with engines and need some clarification on a few things. I got a 1999 dx coupe with the D16Y8 NON VTEC. The motor got like 240k on it and buying a JPM engine to replace and was thinking about going with a vtec engine instead of base model.
My question is if i go with the vtec will it be a direct replacement or will I need to purchase the ECU and harness also for the vtec seperately? Is there anything else i will need for the conversion?
Old Jul 18, 2011
MindBomber's Avatar
Live for the Twisties
Re: DX to Ex conversion
D16y8 is vtec, do you mean your swapping in a b16a2 dohc vtec?
Old Jul 18, 2011
I got the DX model 1999 honda civic manual tranny
Old Jul 18, 2011
d16y7 engine my bad
Old Jul 19, 2011
MindBomber's Avatar
Okay, I thought that might be the case.
You need the wiring harness and ecu, they're different on the D16y8.
Old Jul 19, 2011
The internal dash on the D16y8 model has the IN-DASH RPM Tachometer will I need to install an EXTERNAL Tach to keep CPU clean of any red lights due to no connection of the INDASH Tach?
Old Jul 19, 2011
MindBomber's Avatar
No, you already have the wiring for a tach sitting behind your cluster in reality there's just no tac on your cluster.
Old Jul 19, 2011
Thanks for you insight I am not to smart when it comes to engines but with some research I can figure it out!
Old Jul 19, 2011
MindBomber's Avatar
No problem, happy to help.
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
AceKicker
Jun 15, 2002 01:01 AM
