5speed gas mileage
Old Apr 14, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
5speed gas mileage
k i have a 5 speed ex coupe and i always hear that manual cars get better gas milege than automatics? why is this? i mean how and why? whats so special?
Old Apr 14, 2002
sailorboy's Avatar
sailorboy is an unknown quantity at this point
Auto's have some allowance for slippage, it's how they can stop in gear without stalling. In high gear, most automatics "lock-up" when you ease off the throttle and cruise, it feels like an extra gear shift. It helps with fuel economy on the highway. A clutch in a manual trans. doesn't (usually) slip once you lift all the way off and fully engage it.
Old Apr 14, 2002
Old Apr 15, 2002
Grey's Avatar
DIY King
Not sure about the whole slippage thing, but basically a manual transmition has 5 gears instead of 4. This allows for finer control of the rpm's during all speeds. The lower the rpm's the lower the gas consumption.
Old Apr 15, 2002
someone on here told me that when u shift not to floor it but just press on gas normally and shift at high rpms cuz u get better gas??
Old Apr 15, 2002
Grey's Avatar
DIY King
<< someone on here told me that when u shift not to floor it but just press on gas normally and shift at high rpms cuz u get better gas?? >>
Shift at high rpm's? No! shift at the shift points and accelerate lightly. Read the manual. It's all in the manual.
Old Apr 15, 2002
well i dont shift at high rpms unless im racing or something usually i shift around 3-4 rpms
Old Apr 15, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
if youre going fo gas mileage, then shift early, but if you want speed without killing your gas mileage, then it is better to keep it in gear longer and not floor it.
i just got 41.5mpg from my 5-speed ex coupe [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 15, 2002
avenger's Avatar
avenger is an unknown quantity at this point
here be da 411 ya dig:
autos have a torque converter between the flywheel and the transmission, and this torque converter relies on hydraulic pressure to operate. The engine usually must turn faster than the transmission in order to keep this pressure up. Some autos have lockup clutches that will (at cruising speed) lock up the converter and allow it to be 1:1 like a manual....
for more information
right diggity here
Old Apr 16, 2002
sailorboy's Avatar
Yah, what Avenger said. Thanks for the translation Avenger! You did a lot better job than I did.
Old Apr 16, 2002
k thanks
SidCivic
Sep 12, 2015 05:28 PM
bsmiley
31
Sep 1, 2015 06:11 PM
mrwhos
Aug 11, 2015 02:03 AM
andyandyy
Aug 7, 2015 07:14 AM
beeemerdude
Jul 23, 2015 03:53 PM
