The power of cheese? Or Glass?
Old Mar 30, 2002
ELTsanwich's Avatar
ELTsanwich is an unknown quantity at this point
since we've had the power of cheese we've also been lookin into new powers for that silicon based clear stuff we call glass. we've got the fastest sharpest most clear sond and picture with fiberoptics. glass that bends without breaking?
thought:
if we can fortify glass with something very resiliant to pressure could it regain a space age material status?
properties of glass:
very high melting point
reacts with ALMOST nothing
hard
can be milled to anyshape
fairly light weight
can be milled to a smother surace then 15 microns
aluminum engines are on the uprise. cars are adapting the longerlasting and light weight of aluminum enignes. what about glass engines? crazy compression? tons of boost? WONT RUST?
maybe i'm talkin crazy and people already tried it. maybe just could i get a piston and a rod of glass. just to say i have it?
but if not it would look cool anyway...
Old Mar 30, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
heat is a huge factor here! boiling points and psi and strength is a huge factor! My motor will be made of kryptonite!dakota
Old Mar 30, 2002
NBlarson's Avatar
NBlarson is an unknown quantity at this point
The only problem is glass is actually a very very very viscous liquid, that's why you see that old windows are thicker in the bottom. Heat would accelerate that process, so engines would be melting left and right.
Old Mar 30, 2002
mohawkboom's Avatar
Mazda at one point made a car completely our of Ceramic, Fiberglass and Carbon Fiber. The only metallic parts they used where wiring, and spark plugs.
The Mazda Warlock. a 3.8 million dollar concept car. Weight just under 1300lbs, had a 370 HP Turbocharged v-6. Cost 3.8 Million dollars to make 1.. they made 3 if I recall.
Cheers
Mohawk
Old Mar 30, 2002
Narflar's Avatar
Narflar is an unknown quantity at this point
<< The Mazda Warlock. a 3.8 million dollar concept car. Weight just under 1300lbs, had a 370 HP Turbocharged v-6. Cost 3.8 Million dollars to make 1.. they made 3 if I recall. >>
I'll take two
Old Mar 30, 2002
streetfxracer's Avatar
streetfxracer is an unknown quantity at this point
dude that would be totally cool if that would work but it doesn't so its a totally LAME idea and if mazda has money to throw around like that send some this way pleeeeease[IMG]i/expressions/beer_yum.gif[/IMG]
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
GotSiR
Jun 23, 2016 04:06 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
