2k3 civic!!!
Old Mar 30, 2002
hose2k1's Avatar
hose2k1 is an unknown quantity at this point
2k3 civic!!!
considering 2k3 civc si is on the streets, sooner or later you will find someone on ebay auctioning a wrecked si with a good engine .. will it be easier to swap the si engines in our cars then an rsx engine?? just a thougt
opinions are welcome ...
if your gonna HATE peace yourself out of my topic!!!
Old Mar 30, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
No, its the same motor as the base RSX. So it will be just as difficult.
Old Mar 30, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Yeah chances are it'll be the same. They both have transverse engines jus like ours so its not gonna be any easier I dont think, we all kno RSXs and 7thgen Civics have a lot in common.
Old Mar 30, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
I can somewhat agree that the swap is possible. Just look at the engine bay of the Si. If you haven't seen it before, it's about 2/3 or 3/4 the size of our cars and the RSX's.
Old Mar 30, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
when you do an engine swap, is it the entire engine that is swapped or bits and pieces? would the transmission be a factor?
Old Mar 30, 2002
Spider883's Avatar
9K Redline Owns U
its would be the same thing as the rsx base engine. and the whole engine, trans, and drive shafts are swapped.
Old Mar 30, 2002
Cyclosporine's Avatar
Cyclosporine is an unknown quantity at this point
Probably by the time the type R's here and someone is dumb enough to wreck it, an engine swap with the RSX engine might be posible, but I would lean to the RSX engine since an RSX is more common and you could get the engine for a better price and there's already aftermarket support for it...and for the type R's engine...no aftermarket support for now, and it will end up being more expensive to do the swap since it's an engine from an uncommon car in the states even if it's the same engine, if I were you...I would spend my money on the RSX engine, it would be much easier and "cheaper" [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 30, 2002
Blv's Avatar
Blv
Blv is an unknown quantity at this point
<< Probably by the time the type R's here and someone is dumb enough to wreck it, an engine swap with the RSX engine might be posible, but I would lean to the RSX engine since an RSX is more common and you could get the engine for a better price and there's already aftermarket support for it...and for the type R's engine...no aftermarket support for now, and it will end up being more expensive to do the swap since it's an engine from an uncommon car in the states even if it's the same engine, if I were you...I would spend my money on the RSX engine, it would be much easier and "cheaper" >>
the civic type-r engine is exactly the same as the RSX type s engine, so aftermarket support will be plenty
Old Mar 30, 2002
ThUgGiNAzN's Avatar
ThUgGiNAzN is an unknown quantity at this point
b16 in a 7th gen civic? hehehehehehehe i wish!
Old Mar 30, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
<< considering 2k3 civc si is on the streets, sooner or later you will find someone on ebay auctioning a wrecked si with a good engine .. will it be easier to swap the si engines in our cars then an rsx engine?? just a thougt
First of all its 2002 Civic Si not 2003- they were released late so theres some knowledge for future reference. And the Si's engine is a K20A3..same as a base RSX..so NO it wouldnt be easier
Old Apr 1, 2002
hose2k1's Avatar
thanks
Old Apr 1, 2002
Grifter's Avatar
Grifter is an unknown quantity at this point
Speaking of 2003 civic the none si sedan is ringing in the end for our cars.. aftermarket support and speed... after this year if you want a civic your gonna hafta go with the si hatch..... though thats not neccesarilly a bad thing... but with their markup of up to 23,000 I'm gonna miss a 15,000 dollar car thats lots of fun to play around with
Base Engine Size: 1.3 liters
Base Engine Type: Inline 4
Horsepower: 93hp @ 5700 rpm
Torque: 116ft-lbs. @ 1500 rpm
Automatic: 48 mpg / 47 mpg
someone out there correct me if I'm wrong
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
