Whats The Lower Control Are For??
Old May 23, 2007
IrockCivics's Avatar
I went to get a change of oil and when the car was done they gave me a little list of stuff I need done to my car and one of the things was that I need is lower control arm I have no clue where it goes and what does it do but my question is could that be why the passenger side rear rubs? Because the left side does'nt rub at all I can speed and do whatever and it does'nt rub or nothing but the right side does I can make a left turn and it rubs I can go over a little dip and it rubs could that be the lower control arm? and my right is lower then the left.
Old May 23, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Re: Whats The Lower Control Are For??
its for your rear suspension, get under ur car in the back and take a look your rear strut is connected to it, rear sway.... dang alot of stuff lol, and yea its pretty much a main part of ur suspension
hope the pic helps
for more in depth.... http://auto.howstuffworks.com/car-suspension1.htm
Old May 23, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
I doubt you need an entire lower control arm...
Old May 23, 2007
In the paper it says I need one... But could that be why the passenger rear is rubbing?
Old May 23, 2007
LT2004ever's Avatar
definately, but get under there ant look for yourself... if its like for some reason cracked, or just all messed up, then thhat could def be the problem.
Old May 23, 2007
it could be bad bushings somewhere too. i always called that part of my car a trailing arm.
Old May 23, 2007
Ok I will check tomorrow and I will get back to you guys, thanks.
Old May 23, 2007
skipbarber's Avatar
we have control arms up front, trailing arms in the back. if they called the control arms, they are either bent or the bushings are cracked or worn. which is most likely the case because the stock bushings are angled for stock suspension, when you lower the car it bends the bushing and puts a lot of stress on it. I know for a fact mine are done, and ive seen 3 lowered 7thgens in the past month with the same thing. and if thats the case, buy yourself the ES inserts for $50 and take it to a better shop to install them or DIY with a press.
Old May 23, 2007
yep, that's what i thought. control arms up front, trailing back.
Old May 23, 2007
Originally Posted by Sujak
honda is full of dumbasses (well dealerships)
the ysaid my sister needd new tranny fluid, filter, cabin filter etc
all costing $300
i checked it all everythign was fine
holy crap. and they could obviously tell the tranny fluid needed changed because they have x-ray transmission vision.
and i've never changed a cabin filter in any car i've ever had. maybe i will on this one though. maybe...probably not.
Old May 23, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
You type like a 6 year old. That is all.
Old May 25, 2007
modoman's Avatar
dealerships always try to screw people with the cabin air filter... it doesnt hurt to replace it, but it's hundreds in labor for a $20 part that you can do yourself; it isn't really necessary, though. it's just a filter for the incoming air, so if you have bad allergies it can be a nuissance.
Old May 25, 2007
LiKEaFeRiO's Avatar
If you live in an area with a lot of dust or crap in the air, it will help to clean or replace the in-cabin air filter.
If your a/c seems to blow weaker than before you should inspect the filter.
I usually just smack the dust out and vacuum the filter so I can just reuse it.
Old May 25, 2007
speedfoos's Avatar
Bwahahahah!!! That's funny and I don't care who ya are!
Old May 25, 2007
DsevenEm2's Avatar
This is Myspace
lol...how do i change or find the cabin filter...WAIT NO STOP SHUT UP I KNOW....SEARCH............................
Old May 25, 2007
Alpha 5's Avatar
^^^^^ It is behind the Glove Box. Now seach.....LOL
Old Jun 4, 2007
I checked and everything looks normal and I found where my tire is rubbing at, lemme know what should I do?
Old Jun 4, 2007
skipbarber's Avatar
try some 3mm wheel spacers from ebay as a quick fix. what springs are those?
Old Jun 5, 2007
h&r's springs.
Old Jun 5, 2007
do you have a lot of negative camber in the rear?
Old Jun 5, 2007
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
DO you have heavy stuff like a big sub in the back?
Old Jun 5, 2007
Yeah it looks like I do. But it looks like the side that is rubbing is lower then the other side.. I could be wrong but it looks like it, I will check later again.
I have two 10inch alpines, and the spare tire.... Do you think If I put my 17's will it still rub?
Old Jun 5, 2007
Would it still rub if I put my 17's on? and camber kit?
Old Jun 5, 2007
skipbarber's Avatar
youre not running a camber kit now? if so, thats probably your problem, the car is probably squating too much. you need to bring the camber out a little more towards positive.
Old Jun 5, 2007
Nah no camber kit..... I was thinking about getting this one from ebay..... http://cgi.ebay.com/ebaymotors/RSX-0...18346173QQrdZ1 .... What do you think?
OptimisticWay
46
Oct 15, 2015 02:16 PM
alwaysloyal360
Jul 29, 2015 02:26 PM
brainwashedmc
Jul 27, 2015 10:05 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
