Vibrating door panels are...
Old Mar 13, 2002
WhopSi's Avatar
WhopSi is an unknown quantity at this point
Driving me nuts!! I still ahve the stock speakers in my car, and I can't really complain about the stock system cuz it aint that bad, but when I start to crank the volume, my door panels start vibrating like a ****-stars favourite toy! It sounds like theres some distortion in the speakers but i've made sure and it is the door panels...anyone with the same problem, and how can I fix this??
thanx
Old Mar 13, 2002
civicdragon's Avatar
civicdragon is an unknown quantity at this point
Mine the rear deck vibrates. Played the factory radio a little to loud and now its loose.
Old Mar 13, 2002
choiboy19's Avatar
choiboy19 is an unknown quantity at this point
if its the rear deck, try tightening the bolts, for me the 3rd brake light vibrated so i shoved a sock in there to muffle it.
Old Mar 13, 2002
avenger's Avatar
avenger is an unknown quantity at this point
pound on the rear deck with your clenched fist, then go into your trunk and check to see if all the white clips are snapped in and not just sitting on the metal out of their hole
Old Mar 13, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
if all the clips aren't in, then it'll vibrate like a ****. if you've checked and all the clips are in, then try some sound deadening material if it's still bugging you. there's been a lot posted about that, search for it.
Old Mar 13, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
try dianomat for the front door rattle. it worked for me.
there should be a DIY for front door panal removal. start there.
honestly it helped w/ alot of my rattle.
Old Mar 13, 2002
PlatnumBomb's Avatar
PlatnumBomb is an unknown quantity at this point
I just bought a roll of RAAM mat...It's gonna be plastered all over my car...No more road noise for me!!!!
AHahahhahaha
Old Mar 13, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
<< if its the rear deck, try tightening the bolts, >>
which bolts are you referring to?
Old Mar 13, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
dynamat works wonders![IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 13, 2002
WhopSi's Avatar
where can i buy dynamat??
if your gonna say pep-boys please keep in mind i live in canada
Old Mar 13, 2002
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
I hate it....like if my music is past halfway...on my factory system....then my front right door panel makes a rattleing noise....ahhhh POS.....and when I push on that part were there is that little shelf or place to hold stuff on the door by the bottom...it stops....so mabey it is loose to???
Old Apr 11, 2002
lestat's Avatar
lestat is an unknown quantity at this point
WhoopSi, der should be some dynamat in a local audio/car performance store.
GotSiR
Jun 23, 2016 04:06 PM
alaga
25
Aug 13, 2015 04:42 PM
theteju
Aug 5, 2015 06:59 PM
glockma630
Aug 1, 2015 10:30 AM
ballmich
Jul 9, 2015 11:59 AM
