WANT DUAL EXHAUST? READ THIS!!!!!!!!
Old Mar 8, 2002
civiccowboy's Avatar
civiccowboy will become famous soon enough
I found a site that explains exhaust theory! CLICK HERE!!!! Looks like a go-ahead for duals!!! WOOHOO!!!!
Old Mar 8, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
thanks for the info.
Old Mar 8, 2002
thundercats4ever's Avatar
thundercats4ever is an unknown quantity at this point
Man I trust everything I see on Geocities sites. Plus I would still laugh at you if you did it.
Old Mar 8, 2002
fourkilos's Avatar
fourkilos is an unknown quantity at this point
i heard that dual exhaust on our civic is a no no..
Old Mar 8, 2002
rhyno's Avatar
rhyno is an unknown quantity at this point
Most of his "science" sounds pretty sound. It really goes along with what everyones saying anyways, just illustrating it a little better. The only real contreversy in any of this is "the backpressure myth."
Old Mar 9, 2002
All I did was do a search for "exhaust backpressure theory" and this was one of the results. There are others. Try it for yourself. I read that site on geocities as, the headers and cat produce all the necessary backpressure and all the muffler does is reduce noise. So, you should be able to run with no muffler without a drop in power. And running duals would be ok because it just affects the sound and not the performance of the engine.
Old Mar 9, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
yeah read the article about losing low end pressure our civ's dont push enough gas out of there.....its a no go
Old Mar 9, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
As long as you split the exhuast after the catalytic converter, it won't hurt your performance. This has been discussed before, and you would be retaining enough backpressure to keep your power.
Old Mar 9, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
This could be discussed till the cows come home, but personally, the only way I see it actualy gaining power is if you have some kind of power adder. I think our civics look better with only one exaust tip only. One big fat one, not a coffee can exaust , but a good 3-4 inch tip.
Old Mar 9, 2002
I read another article that said that less backpressure means less low end power and more high end power. Personally this is what I want anyway! I love to play around the redline. I was looking at Thermal Research & Design exhausts and they sell one for low end power and one for mid to high end power. I want more power in the VTEC range(4200-6800). And I dont think there would be any less backpressure with two free flowing mufflers than with one. Just look at them! You can see straight through! and they are larger diameter than the stock pipe! Do you really think they make ANY backpressure!! Come on folks! Lets just give it a try or just do what makes you happy! Its your car. Make it unique.
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
Causemo
Jul 5, 2015 06:42 AM
MamaBear2015
Jun 11, 2015 07:33 PM
