ground control question
Old Feb 28, 2002
slowroll's Avatar
slowroll is an unknown quantity at this point
How exactly do u adjust the height on ground controls and how do u know if theyre even on both sides, wouldnt if be dangerous if they were uneven?
Old Feb 28, 2002
TOOLOWCIVIC's Avatar
All you do is jack up the side you want to raise or lower. There is a gold ring you turn it left for down or right for up. It even tells you on it. It is easy. Take about 10 minutes.[IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 28, 2002
rhyno's Avatar
rhyno is an unknown quantity at this point
it comes with a little allans wrench. like he said, jack it up, loosen the screw and raise or lower the collar. i find the easiest way to tell that they are even is to count the threads.
Old Feb 28, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
Try measuring the distance from tire to wheel well on each corner. Sometimes weight displacement can be off a little on one side more than the other. Best way to have a car that's level!
Old Mar 1, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
I usually count the threads.
Old Mar 1, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
count the thread works and measuring a wheel well distance work too! You must always consider weight distribution. Coz if not, even you have all the same thread count on all four your car will still be uneven
Old Mar 1, 2002
SpdRcrChk's Avatar
BOOST JUNKY
<< count the thread works and measuring a wheel well distance work too! You must always consider weight distribution. Coz if not, even you have all the same thread count on all four your car will still be uneven >>
Yeah that's true. But once you get a thread count on all four sides when the car is even, you can pretty much calculate for the next time. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 1, 2002
slowroll's Avatar
thanks, i havent gotten them yet, would u all recommend ground controls and koni yellows?
Old Mar 1, 2002
ripper's Avatar
ripper is an unknown quantity at this point
Dude, thats sounds good to me, I'm probably gonna get that setup. Just remember, if you raise or lower your car, you should get it aligned. We had a problem with that on an accord I'm building. The tires kept getting messed up as time went by. So we got it to the height we finally wanted it, and aligned it, and it's been great. Good Luck!
Old Mar 1, 2002
slowroll's Avatar
what kind of camber kit would i have to get and how much do u think it would all cost
Old Mar 1, 2002
ripper's Avatar
We didn't use a camber kit, just took it to the alignment shop.
Old Mar 1, 2002
Absolute's Avatar
Absolute is an unknown quantity at this point
get INGALLS... it goes for about $230-$300 all 4 wheels with/alignment,installation...
its just if you got ground-control "coilovers" whats the point of cambering your car... if your always adjusting the height!?!?!
Old Mar 1, 2002
slowroll's Avatar
i thought u had to have a camber kit when u lower your car so much
SugarRay
Dec 6, 2001 05:17 PM
my2k1vic
Nov 29, 2001 10:29 PM
1028CiViC
Nov 27, 2001 02:45 PM
1028CiViC
Nov 24, 2001 02:14 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
