Tire Rotation
Old Feb 19, 2002
xhl's Avatar
xhl
xhl is an unknown quantity at this point
Tire Rotation
I want to start rotating my tires every 5,000 miles. I'm now at 14,000 and about to hit 15,000.
Please let me know if these are the right procedures. Thanks.
1. Put the car on 4 jack stands.
2. Take off all 4 tires.
3. The front two are moved straight to the rear.
4. The rear two switch sides and are moved to the front.
I'm just worried that I might mess up putting the car on the jack stands and have my car crash to the ground while the tires are off.
Old Feb 19, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
From what I recall it used to be front to back and back to front. Since better tires have come out you rotate them in an X pattern.. Left Rear goes to front right, right rear goes to front left, etc... I may be wrong though
Old Feb 19, 2002
CiViCsIkNeSs's Avatar
CiViCsIkNeSs is an unknown quantity at this point
YOU HAVE TO MAKE SURE YOU DONT HAVE DIRECTIONAL TIRES... IF YOU LOOK ON THA SIDE WALL OF YOUR TIRE IT SHOULD HAVE AN ARROW POINTING WHICH WAY YOUR TIRE SHOULD SPIN...I ROTATE MY TIRES EVERY TIME I CHANGE MY OIL (3,000 MILES) AND ONLY LIFT ONE SIDE OF MY CAR AT A TIME... I JACK UP ONE SIDE FIRST AND BRING (LET SAY TA RITE SIDE) THA TIRE O THA REAR RITE TOTHA FRONT RITE AND THA FRONT RITE TO THA REAR RITE... THENI DO THA SAME FOR THA OTHER SIDE
Old Feb 19, 2002
xhl's Avatar
xhl
The stock tires aren't directional, are they?
Old Feb 19, 2002
xhl's Avatar
xhl
Btw, I got the rotation pattern from Firestone's website. It's the pattern they suggested for FWD cars.
Old Feb 19, 2002
I BELIEVE IF YOU HAVE STOCKS THEN YOU ROTATE IN THA X PATTERN (RITE REAR FRONT LEFT...LEFT REAR RITEFRONT
Old Feb 20, 2002
Brandon's Avatar
Brandon is an unknown quantity at this point
I just did mine last weekend. Front-to-back, then criss-cross the rear's up to the front. I had a hard time putting my jackstands under the Civic, so I took out the spare tire and used that. I loosened all the lug nuts and then took off one tire at a time and used the spare as a fifth tire. That was much easier for me.
Old Feb 20, 2002
LiKEaFeRiO's Avatar
If you have your stock tires, then they are non-directional. Your instructions are for non-directional tires and therefore they are correct of you still have stock tires. Look at your manual, it tells you how to rotate directional and non-directional tires.
Just know that our stock tires are non-dirctional and then look at the manual.
Old Feb 20, 2002
LiKEaFeRiO's Avatar
BTW, if your following the harsh driving condition guide in the manual, your 4,000 miles over the recommended mileage for tire rotation.
Old Feb 21, 2002
xhl's Avatar
xhl
Brandon: Thanks for the idea! Now I don't have to go buy jackstands.
OptimisticWay
46
Oct 15, 2015 02:16 PM
SidCivic
Oct 3, 2015 06:00 AM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
