rewriting the laws of physics to go faster....
Warning, this will drain IQ points. but it's funny as ****:
http://www.s2ki.com/forums/index.php...c=360421&st=25
cliff notes:
continued:
BUAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAAHAHA
finally (and 24s2k7 is being sarcastic now, mocking the morons):
cliff notes:
Originally Posted by turbo_jimbo,Feb 12 2006, 05:54 PM
no, i would always opt for the more humid place to get better dyno numbers.
turbo xs had a problem with people complaining about their numbers, so they changed the humidity levels to be much higher than actual humidity and people stopped complaining.
continued:
Originally Posted by kayvan
buddy, please believe me when I say humid weather kills performance. Like do you ever feel how sluggish your car feels when it's super humid outside???
no, but i feel how sluggish it is on 5psi... humid days make more power. if you dont believe me go look it up. you should still have your high school books youre only 17 right?
Originally Posted by S2oooNVegas
dude, at sea level you make more power, WAY more. why, more humidity.
seriously, go look it up. it'll be educational for you since you dont believe me...
too much water, like completly submerged, will net a loss of power, but vapor like that to make up higher humidity numbers will net a gain of power. its simple chemistry. honestly.
Originally Posted by gary_phd
Relative humidity: an amount of water vapor in unsaturated air; ratio of vapor pressure in air/saturated vapor pressure x 100%. Sorry, but when you saturate the air with WATER (humidity), you decease GAS vapors (i.e., oxygen).
The oxygen in the water is bound, and unusable. This is why you can't breathe underwater. banghead.gif If our engines could cause a nuclear reaction to detach the oxygen molecules from the hydrogen, then damn!
Originally Posted by hackmac87
actually jim is right do the reserch cooler more humid air is better for performance. ie water injection the water is denser and so has a better latent heat transfer ability that when it enters the combustion chamber it is evaporated absorbs heat which inturn acts as a retardant like having higher octane fuel thus burning more efficiantly, and provides minor oxygen supply for the cooling effect ie cooler air is denser air.
geez, where do you guys get all your information? Water and alchy injection lowers combustion temperatures - NOT add oxygen (i.e., DENSER)!!!
dude do some more reserch ive been using water injection for years!
Last one for good measure...Hack, not to be rude, but I'm getting the feeling that you may not be the brightest tool in the shed...you need to read your own link. It's the cooling effect that is the benefit, NOT "burning" water - or according to you, adding humidity
Originally Posted by 24s2k7
Here is what really happens. Nitrous increases the humidity in the air, which means more H2O. Then our nuclear reactor boxes break down the H2O into Hydrogen and Oxygen particles. The hydrogen makes our cars lighter while the oxygen gives us more power.
I Hunt Goats, Rams, And Mustangs.
Originally Posted by turbo_jimbo @ Feb 12 2006, 05:51 PM
back to high school chemisty... chemical make up of water... h2o thats 2 parts oxegen for each part of hydrogen. moist air is heavier, which means more dense. which means more air, which in turn means more power. its simple.
Drunken Master-7thgen Ninja
no, he was claiming that the more humidity air had, the more dense it was.
humid air is less dense because of the water. but some people think that humid air makes a tiny bit more power because of evaporation cooling the air. i really could care less actually.
well, its humid as **** here in ga. and i know when i breathe in when it is, it does in fact, feel thicker. i mean you can literally feel and almost drink the humidity down here. it sucks. but idk. someone who knows post it up. im not sayin it will make more power, but does humidity make the air denser or not?
over here its usually 100% humidity. you can breathe air in and its like drinking water almost ha. stuff rusts up in an hour instead of years.
Originally Posted by TransformedBG
and the fact that its more dense mean your getting less in to the engine..
Originally Posted by MajinB
yea it is but its cause of the moisture that its more dense. it don't mean more power tho
the more humid air is THE LESS DENSE IT BECOMES!!!
you WANT the air to be MORE DENSE because that means there is more oxygen per cubic inch of air.
Originally Posted by nv_usracing
that video is one more reason to hate on people with mustangs
while you may gain a tiny little bit of power from evaporation and cooling effect, you're still losing much more because the air is not as dense.
no matter what the conditions are, the more humid air is, the less density the air has, therefore the less power to be made.
From someone who lives in Florida I must say....
Those people are ****ing idiots....
oh come on guys.
density refers to how many molecules are in a given volume of air. this is NOT the same as WEIGHT!!
i knew i wasn't dumb-
Effect of water vapor
For moist air, the partial pressure of the water vapor must be considered as well. In this case, the density of the air is the sum of the density of the dry air and the density of the water vapor:
http://en.wikipedia.org/wiki/Air_density
Autocross Junky
Sad thing about this... I know both turbo_jimbo and S2oooNvegas. and while jimbo may not have the best grasp on physics, he's a good guy. where as SRD...(S2oooNvegas) (SRD is short for Street Racer Dave)..... well... mom allways said if you cant say something nice, dont say any thing at all. BTW, SRD's AP2 is tha Fastest Car in the entire world... Its unbeatable in his own mind.... ya... its that bad.
then why does it feel thicker when its humid? i mean air is a mix of different gases anyway, so its something that confused me.
directly from princeton university:
Most people who haven't studied physics or chemistry find it hard to believe that humid air is lighter, or less dense, than dry air. How can the air become lighter if we add water vapor to it?
Scientists have known this for a long time. The first was Isaac Newton, who stated that humid air is less dense than dry air in 1717 in his book, Optics. But, other scientists didn't generally understand this until later in that century.
To see why humid air is less dense than dry air, we need to turn to one of the laws of nature the Italian physicist Amadeo Avogadro discovered in the early 1800s. In simple terms, he found that a fixed volume of gas, say one cubic meter, at the same temperature and pressure, would always have the same number of molecules no matter what gas is in the container. Most beginning chemistry books explain how this works.
Imagine a cubic foot of perfectly dry air. It contains about 78% nitrogen molecules, which each have a molecular weight of 28 (2 atoms with atomic weight 14) . Another 21% of the air is oxygen, with each molecule having a molecular weight of 32 (2 stoms with atomic weight 16). The final one percent is a mixture of other gases, which we won't worry about.
Molecules are free to move in and out of our cubic foot of air. What Avogadro discovered leads us to conclude that if we added water vapor molecules to our cubic foot of air, some of the nitrogen and oxygen molecules would leave — remember, the total number of molecules in our cubic foot of air stays the same.
The water molecules, which replace nitrogen or oxygen, have a molecular weight of 18. (One oxygen atom with atomic weight of 16, and two hudrogen atoms each with atomic weight of 1). This is lighter than both nitrogen and oxygen. In other words, replacing nitrogen and oxygen with water vapor decreases the weight of the air in the cubic foot; that is, it's density decreases.
Wait a minute, you might say, "I know water's heavier than air." True, liquid water is heavier, or more dense, than air. But, the water that makes the air humid isn't liquid. It's water vapor, which is a gas that is lighter than nitrogen or oxygen. (Related: Understanding water in the atmosphere).
Compared to the differences made by temperature and air pressure, humidity has a small effect on the air's density. But, humid air is lighter than dry air at the same temperature and pressure.
more info:
here's the answer to your question as to "why does more humid air FEEL heavier/thicker when it's humid"
http://science.howstuffworks.com/question651.htm
Ok, so are we clear on this now?
(by the way, i was incorrect on the density/weight thing. density is weight. and yes, more humid air WEIGHS less even though it doens't feel that way)
Compared to the differences made by temperature and air pressure, humidity has a small effect on the air's density. But, humid air is lighter than dry air at the same temperature and pressure. [/I]
my only problem with that is when the humidity rises, temp and presssure are sure to change.
come on dude, you're smarter than this. dont put yourself into the same circle as these clowns who claim humidity is better because it makes the air more dense.
