Interesting review on the ACURA CSX !!! HEY The Engine Is a K20Z2 Not a K20A3!!!
Old Dec 6, 2005
_Viper_'s Avatar
Acura CSX available only in Canada;
what a pity for everyone else!
JIM ROBINSON
Canadians, as a whole, are more inclined towards smaller cars than our American cousins; but like them, we are moving ever upmarket in terms of our luxury leanings.
To meet this seeming incongruity, Acura has launched the 2006 CSX, a compact car with the look and feel of luxury.
The CSX, as far as I know, is the only car made in Canada, by Canadians, just for Canadians.
As opposed to some cars built in other countries and sold here like the smart car, the CSX is built solely in Honda's production facility in Alliston. The two plants there represent a total investment of approximately $2 billion. It also sources more than $2 billion annually in goods from Canadian suppliers as part of its commitment to be a company powered by Canadians for Canadians.
With 4,300 workers at its two plants, they produce the Honda Pilot, Ridgeline and Civic coupe and sedan, and the Acura MDX.
It seems like going to a lot of trouble to build a car for a very small market base like Canada, but it works for Acura. The CSX is not the first Canuck-only Acura. The Acura 1.6 EL (then 1.7 EL) bowed a decade ago and has always proved a dependable seller in our market.
The CSX fills in the entry-level slot for a five-car, one SUV Acura model lineup that includes the TSX, RSX, TL, MDX SUV, and the range-topping RL.
Mechanically, the CSX shares much, like the platform, with the Honda Civic sedan also built in Alliston.
The most visible similarity is the bi-level instrument panel. A digital speedometer, fuel gauge and temperature gauge are housed in the upper level to be more in-line with the driver's line-of-sight. The lower level of the instrument panel houses a tachometer, multi-information digital display, odometer with trip meter and a variety of warning indicators.
But there are significant differences from the Civic as well.
Where the Civic sedan has a single overhead cam 140 hp, 1.8-litre engine, the CSX has a dual overhead cam 2.0-litre, derived from the Acura RSX performance coupe, producing 155 hp. The five-speed manual or optional five-speed electronic automatic transmissions, are essentially the same as the Civic.
In terms of fuel consumption, the five-speed automatic is listed at 9.5/6.5L/100 km city/highway. The five-speed manual gets 8.7/6.4L/100 km city/highway.
The styling is a departure from the Civic but the Honda "look" is definitely there. The CSX has an interesting front fender treatment in the form of a looping arch up and over the front wheel that is carried through to the rear. It is rather elegant.
There are two trim levels, the Touring and the Premium. The Touring model has four-wheel disc brakes, automatic climate control, premium cloth upholstery, six standard air bags, drive-by-wire throttle system for more responsive driving, and a six-speaker high-powered audio system that features MP3/WMA compatibility. The Premium factors in leather-trimmed interior with heated front seats, a power moonroof with tilt and sliding shade, high-intensity discharge (HID) headlamps, and a 350-watt audio system with six-CD changer.
Additionally, the Acura Navigation System with Bilingual Voice Recognition is optional on the Premium model. The navigation system also includes illuminated steering wheel-mounted controls and a digital audio card reader to store and play back digital audio files.
Pricing for the CSX Touring five-speed manual/five-speed automatic is $25,400/$26,700. The Premium is $28,100/$29,400 and the Premium Navi is $30,600/$31,900.
The CSX, like the Civic, shares a Honda safety-oriented engineering concept called ACE that stands for Advanced Compatibility Engineering body structure. It reroutes frontal energy in a crash through a network of load bearing structures in the front of the vehicle.
Acura's safety concerns also extend to pedestrians. To help reduce pedestrian injuries, the CSX's hood and fender areas are designed to deform if contacted by the head of an adult or child. Energy-absorbing collapsible hood supports, wiper arms and fender mounts are designed to allow substantial deformation in an impact.
A lot of work went into the suspension, so it gives a combination of sharp handling and comfortable ride. At the front, coil springs over MacPherson struts have been engineered for improved traction and "feel" for the driver. The rear consists of a big, V-shaped lower control arm and a single upper link.
In terms of stopping power, the CSX offers four-wheel discs with four-channel ABS. The brakes are big being 15-inch ventilated rotors at front and 14-inch solids at the rear. The standard wheel is a 16-inch aluminum alloy with a 17-inch offered as a dealer installed option.
An interesting feature of the CSX is Maintenance Minder. It provides an odometer window readout of when to change oil, air filter, transmission fluid, timing belt, brake pads, and engine coolant, even spark plugs. Tire rotation times are also displayed.
In a driving rainstorm so heavy I couldn't take pictures, I drove both the manual and automatic versions in Premium Navi trim. As you would expect from Acura, the quality of the materials used belies the fact this is a compact car geared towards frugal motoring. No corners were cut anywhere and that was especially true of the interior where my co-driver commented several times on the superior grades of materials used.
The bi-level instrument panel is very effective in imparting information. The large, digital speedo readout being set just below the line of sight is better than a heads-up-display because (in my mind) there isn't a series of flickering ideograms that force you to look through them to see the road ahead.
Such are the advances in chassis/suspension engineering that the ride of the CSX is as good as the best luxury sedan on the market only a decade ago. The manual was the more fun to drive with a typically light Honda clutch and shifter. The automatic was a capable performer, but the manual felt faster.
This car has a very, very large windshield because the A-pillar was moved forward to increase the slope of the windshield to make for a swoppier roofline while increasing the cabin area at the same time. Acura uses special interlinked, flat-blade wipers designed expressly for what Acura calls its Forward-Extended Windshield. Now the rain we drove through would have been a challenge at any time, but on the CSX the blades more than did the job especially on Highway 401 passing those endless lines of spray-spewing tractor-trailers.
About the only thing I could find wrong was wind noise from (I think) the rearview mirrors.
The littlest Acura does a lot of things right like being the right size, right price and with the right amount of trim for those wanting a little more from a compact car.
Thus the CSX is an attractive alternative to those who appreciate great engineering with a touch of class.
AT A GLANCE
BODY STYLE: compact near luxury coupe.
DRIVE METHOD: front-engine, front-wheel drive.
ENGINE: 2.0-litre, DOHC inline four-cylinder engine (155 hp, 139 lb/ft)
FUEL ECONOMY: five-speed manual 8.7/6.4 L/100km city/highway; five-speed automatic, 9.5/6.5 L/100km city/highway.
PRICE: CSX Touring five-speed manual/five-speed automatic, $25,400/$26,700; Premium, $28,100/$29,400; Premium Navi is $30,600/$31,900
WEB: acura.ca
Cliffnotes:
CSX is alot more than a regular Civic so thats why it costs more. If it were introduced in the US it would sell like hotcakes
Old Dec 6, 2005
NoiSe's Avatar
so when are you gonna have yours?? Next time I come out, I wanna see it
Old Dec 6, 2005
_Viper_'s Avatar
Patience cuz when you do see it youll get week at the knees my young padawan lolllllll
a small peek ..when you see this in your rearview that means get the Fawk out of my way
Old Dec 6, 2005
NoiSe's Avatar
what colour did you decide on? Silver?
Old Dec 6, 2005
_Viper_'s Avatar
Old Dec 6, 2005
R1Style's Avatar
you sumbitch... WHAT COLOUR?!??!!?!?
Old Dec 6, 2005
DDragon7's Avatar
Im guessing its silver.
Old Dec 6, 2005
zachgeyer's Avatar
looks pertty sweet
Old Dec 6, 2005
iluvmycsx
Guest
Posts: n/a
good find viper
Old Dec 6, 2005
Al Gore FTW's Avatar
jdmtytedoridori
jdm omg
Old Dec 6, 2005
04CivicLX's Avatar
04CivicLX is an unknown quantity at this point
do they call it CDM
Old Dec 6, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
If only the US civics had that leather as an option.
Old Dec 6, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
it better be SSM. represent viper!
Old Dec 6, 2005
TemjinX2's Avatar
are the hids projectors or reflector?
Old Dec 6, 2005
bp_22ca's Avatar
bp_22ca is an unknown quantity at this point
JIM ROBINSON
Interesting... either that is new with the 8th gen or he is wrong, only 7th gen civic sedans were built in Alliston, and add the Acura CSX to the above list obviously.
Old Dec 6, 2005
CiViCPrAnInG2k1's Avatar
for that money, i'll just buy the SI. but then i agree, leather should have been an option in US.
Old Dec 7, 2005
TemjinX2's Avatar
^^i agree.....
The US ex should've been what the csx is now. They should've offered hids as an option too in the US civics. If you can get it on a mazda3, you should be able to get it on a civic.
Old Dec 7, 2005
zen_master's Avatar
God damn it.....
so NICE!
congratz for viper...
btw, it'll stilll better if they can make acura CSX premium spec with Si's engine + 6speed + all other Si's goodies....
Old Dec 7, 2005
zen_master's Avatar
Originally Posted by TemjinX2
^^i agree.....
i second that.
options like:
-HID
-leather package
-paddle shifter
Old Dec 7, 2005
LiKEaFeRiO's Avatar
The CSX in Canada seems like what the old Infinity G20 was...a near luxury compact.
I actually wanted a G20 but couldn't afford it =(
The US doesn't really have near luxury compact cars...the only close thing I can think of is the Mazda 3.
Old Dec 7, 2005
_Viper_'s Avatar
Originally Posted by zen_master
God damn it.....
so NICE!
I honestly believe they will do that in about 2 years ... they will introduce a CSX type -S and why the hell not .. It will be probably offered in white and rally red....
Old Dec 7, 2005
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
Cars like the EL and now the CSX do well up here since Canadians tend to buy more smaller cars than those in the U.S. An example is the fact that the Civic has been the best selling car in Canada for quite some time now.
Old Dec 7, 2005
jhonsok's Avatar
The blackbeauty ES1.
Originally Posted by mandangalo
jdm omg
muahaha..oh yes. us canadians get the JDM civic...i'd be rockin that Mugen body kit if i had a CSX.
Your right, the 7thgen civic coupes were built in ohio and other places. But the 8thgen coupe and si is indeed built in alliston. There is so much demand for that car right now its crazy. Production overtime, everyday, all the time ! My moms at Plant 1 (Civic sedan, coupe, Si). and i'm at Plant 2 working on the Ridgelines, Pilots, and MDX. Just wait till you guys see the 07 MDX..
Old Dec 7, 2005
runner1738's Avatar
it looks like catherine has been driving it with how close the driver seat is and how far back the passanger is
Old Dec 7, 2005
_Viper_'s Avatar
I just checked it out at the dealer the engine is codded as K20Z2 ad not K20A3
Oh welll
Old Dec 7, 2005
runner1738's Avatar
its 155 hp what did you think it would be the si is a k20z2 at 197 so it had to be a little different
Old Dec 7, 2005
_Viper_'s Avatar
hold on a second there im all screwed up i thought the Si was a Z3 engine
Old Dec 7, 2005
TemjinX2's Avatar
its probably just a tweaked k20a3. The 05 type S engine is k20z1 even though its just a k20a2 with Type R cams and the new SI is k20z3.
Old Dec 7, 2005
runner1738's Avatar
maybe its me i thought k20a2 200 , k20a3 160 why would they change it to k20z3 197 and k20z2 155 im confued already boy i feel stupid
Old Dec 7, 2005
_Viper_'s Avatar
cuz the k20a's are no more
its now K20Z's
