GT40R powered 240 A MUST SEE !!!
Old Oct 25, 2005
mrDFWmechanic's Avatar
a friend on another forum has recently started a new project drift 240 and over the past months he's been doing updates and finally got video's of it running. this video is a must see its incredible !!!
CLICK ME TO WATCH A SICK VIDEO !!!
here's some pics for you to enjoy as well .....
Old Oct 25, 2005
Al Gore FTW's Avatar
jdmtytedoridori
holy shat
Old Oct 25, 2005
ncirom2003's Avatar
WOW, that is really really nice but i honestly expected to see alot more hp, but that was at only 12psi so that is freaking nuts. (btw his 2-step sounds mean but its nothing compared to my buddies cobra when it 2-step's)
Old Oct 25, 2005
here's the parts list for those that want to know
SPEC SHEET/PARTS LIST
CHASSIS
- 1990 Nissan 240SX (Silvia)
- Nismo Motor and Tranny Mounts
- Promod Custom 12-point roll cage
- Fuel Safe 15 gallon fuel cell
- Weldon fuel pump 2115
- Weldo fuel pressure regulator
- JDM S13 rear end w/4.10 final drive and custom oversize axles, Kaaz two-way limited slip
- Cannon Engineering custom drive shaft
- New OEM wire harness
- Stack digital dash cluster ST8130
ENGINE - SR20DET
- HKS Cams stage 3
- HKS Lash killer kit ( solid lifter kit )
- Greddy Valve Springs
- Crower Retainers
- Ferrea Custom Valves
- Greddy Rocker Arm Stoppers
- Greddy Adjustable Cam Sprockets
- Cylinder head square ported and polished by Mo Flo
- Apex’I 87mm head gasket
- Greddy 87mm pistons & rings
- Greddy rods & wrist pins
- Golden Eagle sleeves
- New OEM Oil Pump
- New OEM Rear Main Seal
- ARP Main Bolts
- Greddy Head Studs
- Greddy Oil Pan
- OEM Main and Rod Bearings
- Exedy triple plate carbon clutch kit
- B&M short shifter
- Nismo shifter
- Skyline brake & 5 lug conversion
- Greddy Electronic Boost gauge
- Greddy Electronic oil pressure gauge
- Greedy Electronic EGT gauge
- Greedy Electronic Boost controller
- Greddy Turbo timer
- Greddy Intake Manifold (ported by Mo Flo) w/custom 90mm throttle plate, Q45 throttle body
- Greddy Oil pan
- Custom Full-Race stainless turbo manifold
- Custom Fuel Rail
- Rochester 1600cc Injectors
- SplitFire Coil Pack
- Garrett GT40R dual ball bearing turbocharger
- 44mm Tial Wastegate
- 50mm Tial Blow-Off Valve
- Full-Race Custom 4” stainless down pipe
- Full-Race Custom stainless dump tube
- Full-Race Custom stainless exhaust manifold
- Apex’I GTR Intercooler Core
- Apex’I 3” IN Tanks
- Burns 3" aluminum intercooler U bend piping
- Meziere electric water pump
- Koyo radiator
- Dual FAL fan's
- Blitz upper radiator hose
- Samco lower radiator hose
- AEM 3.5-bar MAP sensor
- AEM EMS engine management
- AEM WEGO wide band a/f sensor w/gauge
Old Oct 25, 2005
ncirom2003's Avatar
one problem, ohc style engines dont have lifters. (unless this motor is some out of the ordinary motor that the wanted to design to be inferior and they stuck lifters in there somehow.)
Old Oct 25, 2005
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
video is dl
looks sick judging from pics
Old Oct 25, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Holy giant turbo batman. I think this engine is the one I am going to put in my old skool 240z I am just not sure how much it weighs compared to the stock L6.
Old Oct 25, 2005
v8eaterokv6's Avatar
i have a new home do u
amazing he is a very skilled person if he did all that him self. mad props
Old Oct 25, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
damn! that is sick my buddy with an sr20det in his 240 would cream his pants over this
Old Oct 25, 2005
XxJDMCivicxX's Avatar
Team Pacman at it again, I can't wait to see their 1000hp k24
Old Oct 26, 2005
aki's Avatar
aki
aki is an unknown quantity at this point
Wow, that's a nice sounding engine. Cool vid of the turbo spooling.
A minor technical correction: the car is *not* a Nissan Silvia in Japan, it would be a 180SX. The S14 Silvia is only the coupe variant.
Old Oct 26, 2005
anybody know the name of the song playing in the video ?
Old Oct 26, 2005
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
I like that guy when he looks like he is holding down the car on the dyno... then all of a sudden the car back fires and he jumps and tries to play it off.... look closely.
Old Oct 26, 2005
TheSmuggler's Avatar
Actually no... Two models were available in Japan, the 180SX hatchback and the Silvia coupe (commonly reffered to as the S13), both of which are offered here also, but both are called 240's, one being a hatch and one being a COUPE. The 180 also carries the blacktop engine and a differn't ecu. So the S14 isn't the first coupe... When the S14 was released, that was the second coupe offered under the silvia lineup.
Old Oct 26, 2005
aki's Avatar
aki
Er, I meant S13. Either way, the 240SX hatchback is the 180SX; the 240SX coupe is the Silvia. Obviously both are called 240SX stateside, but the coupe/hatch variants have different names in Japan, as well as a different front end.
Old Oct 26, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
wtf is that big *** funnel thing on the turbo????
Old Oct 26, 2005
I was just clearing up your misnomer
Old Oct 26, 2005
Air horn, it replaces the filter on cars that won't need to worry about sucking in water and the like. It also amplifies the spooling sound ALOT.
Old Oct 26, 2005
turboengnr's Avatar
DONT PANIC
it smoothens out the airflow into the turbo.
It doesnt protect the engine from anything.It simply makes the turbo a little more efficient at intaking air.
Old Oct 26, 2005
scatman's Avatar
Still in the game...
link doesnt work?
Old Oct 26, 2005
sweeteli99's Avatar
sweeteli99 will become famous soon enoughsweeteli99 will become famous soon enough
Originally Posted by scatman
link doesnt work?
ditto.
Old Oct 26, 2005
i was workin a while ago i dont know what happened
Old Oct 26, 2005
spoonEM's Avatar
omgwtfbbq mod.
.....i need to use the restroom....ill brb.
Old Oct 26, 2005
PunkingCivic's Avatar
I need TP for my bunghole
go here to see the dyno vid.
http://www.k20a.org/pacman/
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
