Lingenfelter C6 427TT on the dyno...
Old Oct 8, 2005
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
WOW
http://www.lingenfelter.com/C620054271038hp320.mpg
Old Oct 8, 2005
IronFist's Avatar
Wait, I'm confused. How does it not reach it's max hp until 155mph? I thought max hp was reached at a certain rpm in each gear (mechanical function)... he's not staying in one gear through 155mph, is he? Or is that like a CVT transmission or something?
Old Oct 8, 2005
IronFist's Avatar
So there's someone in there, right? What if it slipped off or something and hit the ground with the wheels going 155mph?
Old Oct 8, 2005
JoeyOKC's Avatar
BWAHahahahAHahAhaHAah...go to a dyno and see how the operation works. He was probably in the car in 4th or 5th gear at about 50mph when he hit the gas.
Old Oct 8, 2005
IronFist's Avatar
So if he was at 5th gear he wouldn't hit is max hp rpm until a high speed, then, right?
Old Oct 8, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
no. like said before, he probally was in 4th gear arounf 2k rpm to start and 155 mph mark was probally the redline of 4th gear. he would hit max hp at the redline of every gear, 155 just happens to be when it is for 4th gear. max rpm in 3rd gear would give around the same hp etc.
Old Oct 8, 2005
modoman's Avatar
im assuming the red is torque... whats the point of all the power? doubt you can keep it straight on a track. buuut it'll probably give you a hard on
Old Oct 9, 2005
Spoolin's Avatar
spoolin by you
damn. 3 hours later and i post the same thing. i must be drunk somene cn delete this
Old Oct 9, 2005
spoonEM's Avatar
omgwtfbbq mod.
damnit...if my civic were on that chart....my lines wouldnt even show. hahaha.
i like the burnout he does when he floors it. man..im jealous.
Old Oct 9, 2005
01hx5's Avatar
01hx5 is an unknown quantity at this point
Man i love vettes
Old Oct 9, 2005
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
its wonderful that simply by stepping on the gas at 50mph in 4th gear (even though its on a dyno) that when it hits boost it spins the tires. thats just sickening.
