torque (part 2)
Old Jun 20, 2005
  #31
S2000man01's Avatar
O RLY
Originally Posted by gearbox
correct. before with tuning it was a flat 14. Now its lean again in low rpms and around 13 upper rpms.
actually it has gotten richer. and your ECU is the reason why. 14:1 is LEANER than 13:1. as the number gets smaller, the RICHER the mixture become.
So looking at your dyno how you had it tuned, you had leaned out the mixture for more power. Over time, your ECU took over and tried to counter-correct, making your mixture RICHER to get closer to the stock mappings again. The reason you haven't lost much power is because it didn't change drastically, and your other mods may be helping maintain some power.
Old Jun 20, 2005
  #32
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
13.7:1 is stoichmetric. if you're running 14.7:1 that's actually dangerously lean unless you are idling.
14.7:1 is stoichiometric. It is also not uncommon to cruise at 15:1 or even 16:1 as this conserves fuel.
Old Jun 20, 2005
  #33
hmm thats what i thought. so is 13:1 too rich?
Old Jun 20, 2005
  #34
13:1 is about right under heavy accleration for a normally aspirated engine. 12:1-12.5:1 is about right for turbocharged engines. You can also use BSFC to determine AF ratio. An NA engine will have a BSFC between .45 and .50 and turbocharged will be between .60 and .65.
Old Jun 20, 2005
  #35
S2000man01's Avatar
O RLY
doh yeah 14.7:1. sorry bout that!
you can even get more technical than that if you want. using the amount of addatives in the fuel, you can calculate what the actual stoichiometric rate would be. For example, here in wisconsin, our gas is about 90% gasoline, and the rest are an addative. Our actual stoichiometric rate would be about 14.4:1.
http://home.earthlink.net/~graham1/M...chiometric.htm
Old Jun 20, 2005
  #36
S2000man01's Avatar
O RLY
by the way, I'm so sorry for misquoting the 13.7:1. 13 is not too rich at all under WOT. and idle can see as high as 16 or 17:1. cruising, as 4drcivic2k1 said, also sees leaner rates.
Old Jun 20, 2005
  #37
cool thanks everyone.
Old Jun 20, 2005
  #38
Michalo187's Avatar
Abortion Survivor
good info s2000man01 someone should sticky this for other people to use
Old Jun 20, 2005
  #39
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
ok so lemme see if I have this right. If I were to get the AEM EMS on my car (totally stock engine), it alone wont really do a whole lot, right? However, you're saying that once I throw the bolt ons with the ems I should get more power than normal, correct? Does anyone know about how much of a difference this should make? or was this never done before?
sorry about all the ?'s, just trying to understand all this...
Old Jun 20, 2005
  #40
MYK1013's Avatar
for a second I thought this thread was about Torque, the sequel.
That movie sucked elephant *****!!
Old Jun 20, 2005
  #41
S2000man01's Avatar
O RLY
The AEM EMS alone will give you some gains if you have proper tuning done. And yes, each mod you add after, should allow for some more hp than if you had the stock ECU.
Old Jun 20, 2005
  #42
what i would do if i had unlimited car money
Old Jun 20, 2005
  #43
MajinB's Avatar
Drunken Master-7thgen Ninja
yeah i agree. i would make a d17 that would spank anything. just to prove i can. screw a swap, outsmart everyone else.
Matteo
Oct 25, 2015 05:46 AM
wholt0
Transmission
Jun 11, 2015 11:15 PM
Grey
16
Jan 27, 2002 11:34 PM
SoCalCIVIC
Dec 10, 2001 12:48 PM
silvervtec01
Dec 9, 2001 08:50 PM
