What is D3 for on an auto?
Old Jan 25, 2002
KUNZ's Avatar
KUNZ is an unknown quantity at this point
This might sound stupid but what is D3 for on an automatic? When do you use this? I heard it was really bad to take off in D3 and especially switch to it when you going fast. I just read a forum where the dude said he was racing and it was all over once he put it into D3.
Old Jan 25, 2002
deathor's Avatar
deathor is an unknown quantity at this point
lower gear
use when u need the power
I can't believe this..........[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG][IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Jan 25, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Its okay to drive around with it in town, as long as you are going under 40MPH.
I usually don't use D3 unless if I'm passing someone, and I need some extra power...
You're manual should have all the info you need dude, I found the 40MPH thing in there...
Old Jan 25, 2002
01CivicMike's Avatar
01CivicMike is an unknown quantity at this point
If you are going too fast, it won't downshift anyways. Anytime you downshift with an auto, you should be in the throttle - not for slowing down.
Mike
Old Jan 25, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
try to use on highway...once u switch to D3, u will feel the power
Old Jan 25, 2002
jonavin's Avatar
jonavin is an unknown quantity at this point
If you are in stop-n-go traffic, putting it into D3 will prevent gear hunt between 3 and 4. The Grade Logic works pretty well on Hondas most of the time, but if you are going down a steep hill you may want to force it into D3 for extra engine braking. You could use your brakes but if it's used for extended periods, too much heat might build and reduce the effectiveness of your brakes should there be a necessary emergency maneuver at the bottom of the hill.
And "2" on our autos starts the car in gear 2 -- do this to reduce the chance of slipping on low traction areas (like snow/ice/mud).
Old Jan 25, 2002
emmagatorone's Avatar
emmagatorone is an unknown quantity at this point
<< If you are in stop-n-go traffic, putting it into D3 will prevent gear hunt between 3 and 4. The Grade Logic works pretty well on Hondas most of the time, but if you are going down a steep hill you may want to force it into D3 for extra engine braking. You could use your brakes but if it's used for extended periods, too much heat might build and reduce the effectiveness of your brakes should there be a necessary emergency maneuver at the bottom of the hill.
Perfect answer!
Old Jan 25, 2002
Liquidsnake's Avatar
Liquidsnake is an unknown quantity at this point
Great!!! I was wondering that myself. Yeah perfect anwser thanks
Old Jan 26, 2002
AB's Avatar
AB
AB is an unknown quantity at this point
Do your research boy
Old Jan 26, 2002
racinginindy's Avatar
racinginindy is an unknown quantity at this point
D3 = Race....the car will hit the fuel shut off/limiter in D4, but in D3 it will pull until 6700rpm's baby!
Old Jan 26, 2002
GTR's Avatar
GTR
GTR is an unknown quantity at this point
Please, before posting a topic like this,
1) Search this site, because questions are mainly being repeated over and over again.
2) Read the OWNERS manual
***closed***
Have a nice day
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
ttamrekab
Sep 25, 2015 04:41 PM
Skunkone
Sep 24, 2015 04:38 PM
