H22 mounts for a Em2?
Touch it... He won't bite, He'll just come at you pretty quick.
Originally Posted by k20a3em2
well i have a 2001 civic and preludes were made through 2001. dang tho
New Mod on the Block
Originally Posted by civicvtec1ps
Nobody has them, probably won't ever will.
Harness is not availble and it's illegal to put older engines on anyways.
Engine bay isn't big enough.
Not worth it.
Not worth it.
Originally Posted by umysugarmami
so if i ever wanted to swap in a k20, i would have to find one 03+ since i have an 03 civic?
Originally Posted by ExVtec01
that sucks, o well the k20 are like one of the best honda engines. although i would like to have a c32(NSX). if it fits
i would take a simple K20 and be happy. But I got an 01 so
i can stay legal easier. any K20 is good for me!
i can stay legal easier. any K20 is good for me! Back From The Banned!
Originally Posted by ACURAwerx
I forget which team, but the professional dragster people have nsx engines in 7thgen coupes. i believe they are turbo charges or something. And the fwd runs like 9s and the rwd or something runs like 6-7s? I forget the exact numbers or whatever, its been so long since i looked into it.
Those aren't 7th gens. Those are tube frame cars with a couple body panels that look like a 7th gen and some stickers that look like lights. My SL65 rim, because a rim is all I can afford
Well, in Ohio, you can put any engine into what ever as long as it belongs to the same OBD series and passes emmisions check. So a lude motor that is '96 or newer can go in.
The real question is why? These aren't cheap motors, they don't fit into civic at all, the slant of the motor is in the opposite direction and the axels are not the same. You will not only need custom mounts, you are going to have to have custom axels made, and then you will have an H22A with seriously under cooled. So then you will have to fit a lager radiator in to your already way over crammed engine bay. Not to mention you can't drive in snow or anything because you will have to remove your inner fenders to fit the tranny in.
All that is gonna cost you big bucks, you could easily get a K20 with some bolt ons for less and make more power. Not to mention the reliability of the K20 is far better than the H series (it one of Honda's most unreliable motors ever). Doesn't sound like a good swap to me.
Re: H22 mounts for a Em2?
jus so u kno its been done wether its reliable or not heres a link so yall can see for yourself
http://www.youtube.com/watch?v=iJY3JHZ54Mo
so im guess there is mounts and if you want to do that swap and you have the money then do it. its your car not anyone elses
there are no mounts those mounts are custom and that has been out for a while there is a huge thread on hondatech about that caused a lot of controversie
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
