Need help please!!!!!!!!
Old Jan 23, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
i need help removing the outter ring of the gauge cluster......
THe black plastic surrounding the gauge cluster before your get to the plastic clear
panel that protects the gauges........
I got the top part of the panel out but i can't seem to get the bottom out......
the odometer push toggle and the light push toggle are in the way please help......
Old Jan 23, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i cant see anything in that picture except your hand, the arrow is pointing to blackness
Old Jan 23, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i'm not quite sure which piece you're talking about but just PULL! good luck!
Old Jan 23, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
After you pull the top portion off, the bottom is connected by two clips, one on each side of the steering column....
you just have to pull it out...it will take some force, but it will pop out. Get your fingers in the crack between the
bottom of the black peice and the plastic clear piece near the back and just yank it out.
Old Jan 23, 2002
GTekCiViC's Avatar
ok thanks
Old Jan 23, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
thanks for the info
