The worse thing about cheating is getting caught
Old May 8, 2005
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
BAR/Honda F1
sux for them.
Old May 8, 2005
R1Style's Avatar
I didn't read anything in there that explained why they were banned...
Someone please explain
Old May 8, 2005
dirtySAMURAI's Avatar
I log in from time to time
R1:
BAR-Honda representatives appeared before the appeals body Wednesday to explain why Button's car ran 11 pounds under the minimum 1,322-pound weight at Imola.
there you have it. they ran 11 pounds under
Old May 8, 2005
ImPulse's Avatar
The driver probably forgot to eat his breakfest and lunch?
yea... stuff like that is retarted... just 11 pounds :x
Should have thrown some peices of metal into the cockpit
Old May 8, 2005
R1Style's Avatar
I read that but why did it run 11 pounds under? What was this so called concealed mechanism???
Old May 8, 2005
scizod's Avatar
scizod is an unknown quantity at this point
the fuel tank....
They ran a modified fuel tank. It held the same as everyone else but it also had a hidden 3 gallon resevoir inside that tank. It was very trick. By having that, you can have less fuel in the tank and have the reserve full resulting in a lighter car. They would be running the same amount of fuel as everyone else but with less fuel in the tank. That is basically why they are banned. They said with that done to the car they would shave about 14.5 seconds in a race. Does not seem like a lot but in an F1 race that is like a 1/4 of a lap.
Old May 8, 2005
CivicsRdBest's Avatar
Holy cow that is interesting... Too bad they don't apply that kind of stuff to regular cars, like mentioned they got caught.
Old May 8, 2005
R3DL1N3's Avatar
rules are rules. they get pissy when it comes to racing too, even if it is only 11 lbs.
Old May 8, 2005
Pharoh's Avatar
Bobaganoosh!
I read this a few days ago...sucks big time.
Old May 8, 2005
nickm748's Avatar
11 pounds is a lot in racing
Old May 8, 2005
jttegx's Avatar
OMNES AD UNUM
it more of the opponents that would get all pissy because its making it harder for them. so the officals just did what they had to do. done deal
Old May 8, 2005
jfan's Avatar
Well that is a fair ruling, no complaining here...
Old May 8, 2005
S2000man01's Avatar
O RLY
so it was a TEAM using honda engines? or was this done by honda themselves?
Old May 8, 2005
ToX's Avatar
ToX
ToX is an unknown quantity at this point
Documents showed that Button's car weight 594.6 kg after all of its fuel had been drained, which is below the 600 kg minimum specified by the technical regulations.
"The only way in which the vehicle could meet the requirement of the minimum weight of 600 kg was to have used fuel as ballast, which does not conform to the (regulations)", said the Court.
The Court also noted an additional 8.92 kg of fuel remained in the tank in a special compartment and a further 2.46 kg of fuel remained in the bottom of the tank after team officials had confirmed to race stewards that all the fuel had been drained out.
so 5.4kg + 8.92kg+2.46kg= 16.78kg *2.2 =36.9 pounds
Old May 8, 2005
Hawk's Avatar
You boost, I-VTEC
Honda owns a huge chunck of BAR and were/are planning on buying the team very soon.
It really sucks cause it looked like they had finally gotten their stride back in testing and the car had gotten fast again, now it seems that they were just running light. Really made me lose respect for the people that run the team, i don't know if i can route for them anymore.
Old May 8, 2005
S2000man01's Avatar
O RLY
Actually, some technical information and discovery information was posted on s2ki.com about the situation. It appears that Honda did NOT cheat and that the FIA mechanics KNEW 4 races before this one that the "special" fuel tank existed. Not only knew it existed, but ALSO that ferarri has the same tanks. (however, ferarri changed out their fuel tanks the day after all of this erupted)
More info:
But anyway, the fuel tank was deemed not secret when the FIA Technical Delegate Jo Bauer testified that he knew about the fuel tank since Malaysia 2005 (that's three races ago) when B.A.R allowed him to inspect it as the FIA were inspecting all fuel tanks that weekend. The purpose of this tank is to provide fuel, not air, to be pumped at 50 bar into the engine. The collector requires approx 6kg of fuel to function.
The car was not underweight during the event. The car was not underweight until the FIA made the car undriveable. (by draining this tank, which CANNOT even function if there is no fuel in it) The FIA Court of Appeal didn't even focus on whether the car was underweight or not, but rather how the scrutineering took place and how one of the B.A.R team members answered a question. The question was, "Is that it?" and his answer was, "Yes". What was happening when this exchange took place? A lifted pump drain procedure of the car. All of the fuel that could be removed from the lifted pump procedure drained out until the pump was pumping air. The pump equipment was removed and the Technical Deligate asked a question and got an answer believed to be true based on what the team member thought he was asked.
So in other words, the car is not even driveable without this 6kg of fuel. When they emptied the "extra" tank, it made the car not driveable. So in other words, honda's stance is the car's "dry" weight must still maintain enough fuel that the car is driveable, since all the other cars can drive off after being weighed. However, if that tank dips below 6kg of fuel, the car is no longer driveable, and should not have been weighed at that point. The tank is actually a very innovative fuel delivery system, not requiring any baffling as on other cars.
Old May 8, 2005
Hawk's Avatar
You boost, I-VTEC
they were trying exploit a loop-hole in the regulations. BAR have been doin this for a while now, the illegal brake transfer system, moveable rear wing endplates, this is the first of their little tricks that the FIA didn't catch till after the race. The rules state the car must be empty of all fuel, car was not empty, they were wrong. It makes them and the sport look really bad.
They should just except the fact that they have a mid-pack car and deal with it. It really makes me not want to route for BAR anymore, but i must cause of their engines.
Old May 8, 2005
acidbaby's Avatar
The Beez Kneez
11 pounds is quite a mistake...
Old May 8, 2005
Hawk's Avatar
You boost, I-VTEC
yea and that 11 pounds means that the car was built under regulation weight and needed fuel to make weight, its just sad. I think they should be banned from the season the more i think about it.
Old May 8, 2005
mad_ox1's Avatar
mad_ox1 will become famous soon enough
http://www.vtec.net/news/news-item?news_item_id=352421
The car was never under-weight during the race. It was weighted and passed initial inspection, but the FIA took the step to empty the car and weight it again and found that once emptied it was out of spec by 11lb. BAR maintains that they did nothing wrong and they are considering taking the FIA to civil court over the matter.
Old May 9, 2005
Hawk's Avatar
You boost, I-VTEC
oh boy honda fan-boys on vtec.net, whats funny is the guy posted a quote from the regulations and says that BAR didn't break any of the rules when in fact they broke one he posted
Article 4.1 Minimum Weight: The weight of the car must not be less than 605 kg during the qualifying practice session and no less than 600 kg at all other times during the event.
All times during the event meaning when the car is sitting in the trailer with no fuel in it. The car was built under weight its plain and simple, no matter how much of a fan of Honda or BAR you are (which i have been sence they got Honda power) you can't deny they cheated.
Old May 9, 2005
S2000man01's Avatar
O RLY
You made honda sound like these bad guys who just go around breaking rules. How about toyota? Renault? Ferarri? They all do this. They all push the limits of the rules as much as they can. Sometimes they get caught on it and sometimes they don't. Some things get made more public than others. Toyota did some very heavy rule bending and some unscrupulous practices in recent years.
So to sit here and shake a finger at Honda/BAR would be the pot calling the kettle black so to speak. Why must honda be held to the higher standard, when all the other teams push the rules and find loopholes where they can?
Old May 9, 2005
S2000man01's Avatar
O RLY
Actually you're wrong. The car was never under 600kg during the entire event. Not until AFTER the event and the FIA drained all of the fuel and even REMOVED that fuel equipment, was the car underweight.
The FIA knows they were somewhat "incorrect" in their take on the matter and the punishment. Why do I say that? Because Honda is allowed to not only race again starting May 29th, but the FIA is allowing them to use the same car, without having added any weight modifications. Interesting don't you think?
And as you continue to bash BAR honda, you completely ignored the fact that ferarri had the EXACT same mechanism on their cars, and immediately changed out the fuel tanks the day after the initial blow-up of all this crap.
Old May 9, 2005
mad_ox1's Avatar
While every site does have their fan-boys, I think you'll find that vtec is one of the most unbiased sites out there. Like S2000man01 said, they never were under spec during the event, and even during the post-race inspection. The FIA made a 2nd inspection of the car at a later time. The FIA is trying to do whatever it can to weaken the stance of the GPWC.
It becomes more and more obvious how much they favor Ferarri, in situations like this and in testing because they are the only team to sign on with the FIA beyond the current Concord Agreement. It looks like there will be a breakaway series and F1 will turn into a Ferarri spec series with possibly 1 or 2 other small teams.
You might be interested to see how the other manufacturers feel about the FIA's decision.
http://www.speedtv.com/articles/auto/formulaone/16757/
"The automakers were also not pleased with BAR-Honda’s two-race ban issued by the FIA International Court of Appeal following their alleged use of fuel as ballast in the San Marino GP. The manufacturers perceive the Court as lacking indepencence to argue such cases since it is connected to the FIA."
Old May 9, 2005
bickford05's Avatar
bickford05 is an unknown quantity at this point
damn that sucks... better than being disqualified for the season though
Old May 9, 2005
Hawk's Avatar
You boost, I-VTEC
what you guys seem to be missing is the fact that the car must be weighed dry after the end of the event and make the minimum weight requirement. BAR LEFT FUEL in the FIA aproved second tank, which was suposed to be emptied prior to weighing. Its not that the device that they were using was illegal because it isn't, its the fact that they left fuel in the car when it was supposed to be dry weight. Ferrari might use the same system in the tank, but they empty the tank before weighing, like they are supposed to.
http://www.formula1.com/insight/tech...005/2/111.html
P.S. S2000man, the event means the entire race weekend, not just the race.
Old May 9, 2005
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
but then why did ferrari change their fuel tanks the day this happened?
Old May 9, 2005
Hawk's Avatar
You boost, I-VTEC
because they didn't want the FIA to think they were leaving fuel in their tank? I mean hell maybe they were i have no idea, Ferrari gets away with everything, they are the FIA's golden boys. Shucmacher passed someone under yellow at Indy 2 years ago, and not a word was mentioned about it. If that were to happen with any other team they would be excluded from the results.
Point is that BAR left fuel in a car that is supposed to be empty and that is cheating, plain and simple. No matter if someone else does it or not, they didn't get caught, BAR did. It's sad to see that the team would even think of doin it let alone do it.
If you can't see the fact that a team running a underweight car is wrong (no matter what team it is) then i don't know what to tell you.
Old May 9, 2005
S2000man01's Avatar
O RLY
actually, FIA revised what rule it is that BAR broke. did you notice that? once they saw they were basically incorrect on their initial stance, they changed the charge from being underweight, to using fuel as a ballast. Which BAR is going to continue to argue since there is no way to control the fuel moving from one tank to another. So FIA keeps backpeddling. So no, I don't think they were cheating.
Old May 9, 2005
Hawk's Avatar
You boost, I-VTEC
Where was this, i never saw this posted on any F1 news site, and i read them all.
And they were aparently using the the tank as a ballast, cause it was on the right side of the tank, and most tracks are clockwise.
Now they are being warned by the FIA not to apeal the descision, they should just back off and wait for the Nurburgring race where hopefully they'll get a win, or at least a podium, legaly.
