2 cylinders. 325 hp, 590 lb.-ft @ 2000rpm. 270lbs.
Old Apr 18, 2005
NoFriends's Avatar
I like ruining your threads.
Wow.... Talk about an efficient motor.
http://wardsauto.com/ar/auto_fev_sho...ency/index.htm
Old Apr 18, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
wow, imagine a 6, 8 or 10 cylinder
Old Apr 18, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
similiar to boxter designed motors?
Old Apr 18, 2005
NoFriends's Avatar
Only thing in common is that they are horizontally opposed. And its Boxer, btw.
Old Apr 18, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
wow, very interesting ...
no head, eh? ... there goes the almight vtec ;P
Old Apr 18, 2005
S2000man01's Avatar
O RLY
how so? after all this engine is turbo'd. not to mention it's a 2-stroke engine. completely different than the 4-stroke engine in a car.
Old Apr 18, 2005
Hurts2bStock's Avatar
Shinier than yours, meatbag
wow....thats really cool.... thats kinda like clear duct-tape.....an idea so clever, its amazing it was not thought of before..
Old Apr 18, 2005
dre2600's Avatar
It doesn't actually list the displacement of the motor I don't think, for all you know it could be a four litre 2 cylinder.
Old Apr 18, 2005
^^^^true but it does say it only weighs a few hundred pounds and has that much power at only 2000 rpm
Old Apr 18, 2005
pbfoot's Avatar
its not a mystery that 2 stroke motors are monsters. they always have been. the only bad thing about them was that they dont use fuel efficiently and burn much more oil than a 4 stroke engine. they also produce more pollution. now, if this engine solves these problems, then you can bet that this is the next big thing.
i would LOOOOOVE to see some 2 stroke engines get put to use in something more than a chainsaw or a lawnmower. lol
Old Apr 19, 2005
Got Boost???'s Avatar
2 cylinders 4 pistons, intresting. too bad its extremely impractical because the outer connecting rod is limited on thickness they have to be made of exotic metals, titanium in this case
and actually the more i look at it the LESS efficient it appears to be. Because of its dual piston design it makes for very inefficient removal of exhaust gases.
Old Apr 19, 2005
dre2600's Avatar
Titanium connecting rods aren't too hard to come by nowadays, even for common commercial use, titanium is a lot more ubiquitous than it used to be.
Old Apr 19, 2005
Titleist71's Avatar
yes just like a subaru motor, but only half the size.
Old Apr 19, 2005
eye_see_you's Avatar
let the devil out
I can imagine someone trying to fit this into a civic for the complete sleeper that would just burn all kinds of cars.
Old Apr 19, 2005
ironchef's Avatar
There is no substitute
ironchef is an unknown quantity at this point
Normal 2-stroke engines (ie. lawnmowers, dirtbikes, snowblowers, etc) use an oil and gas mixture due to packaging constraints. The symplified design allows for a smaller and less complex engine, which is vital for these applications.
When you're talking about an engine this size, this is not such a factor, and it's possible that it has a lubrication system much like we're used to on our 4-cycle cars. If this is the case, then it would have better emissions than your average 2-cycle engine. Of course this is just speculation, and we'd have to see more specifications before we can be sure either way.
It will be interesting to see if some of these designs make it into production for mass-consumption applications, and also what the emissions are like on these engines.
Old Apr 19, 2005
_Viper_'s Avatar
I have a titanium butt plug so I guess titanium is easily available nowadays
Old Apr 19, 2005
WannaBFast's Avatar
Prowlin' with a Purpose
actually porsche was the FIRST to implement the boxer motor, subaru was quick to follow and bmw has been using them on their bikes for some time
Old Apr 19, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
well, since there are no valves or cams, no vtec ...
Old Apr 19, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Actually volkswagen was the first to use the horiz. opposed cyl(i belive less the considered steam years). And two stroke diesel have been around for along time. They are still used in trains in a diesel electric config., and in buses and so on. And all though there are no valves(some do have rotory valves) you can adjust the valve timing(which is called port timing) to tune the engine for specific apps. Like my jet ski can be ported for top end or alot of diff specs.
Old Apr 19, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
um, no. its Boxster.
he's talking about the flat engine design in the Boxster. some people call the engine the "boxer" but just about everyone just calls them flat 4's or flat 6's. and its a little similar to the flat design in the Boxster and 911's, but has huge differences also. the biggest would be the porsche engine is a 4 stroke and "that thing" is a 2 stroke. the crank/connecting rod/piston setup is totally different too. I'd put it in my car though if it could turn more rpms. 2000rpm's is not enough for a car. there'd be a lot of blown motors around. and if you just made the gears super long, you'd have a lot of teeth breaking off the gears unless they were made of titanium. and no car company would make a tranny out of titanium....lol. just leave it in aircraft and such that don't require high rpms I say.
Old Apr 19, 2005
hahahah
1 Boxster=type of car girls drive
2 Boxer=type of cylinder geometry
Old Apr 19, 2005
bradmanuwf's Avatar
what did I just say? idiot "some people call the engine the "boxer" but just about everyone just calls them flat 4's or flat 6's" which = boxer......derrrrrrrr
Old Apr 19, 2005
ironchef's Avatar
come on guys, don't argue over this. I don't think the original statement was clear enough. It could be interpreted in any number of ways.
Old Apr 19, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i think we all know where the future of automobiles are headed...2 cylinders generating almost 600 ft-lbs of torque...with a thermal efficiency of 41%...holy ****ing wow...i wonder what kind of fuel efficiency that thing gets...
Old Apr 19, 2005
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
who is this 'just about everybody'? the engine type's been named boxer for over half a century. they've been around at least since the forties...http://www.ukcar.com/history/Porsche/
a guy named porsche designed it, his company named the boxster almost 50 years later...and just happened to put a boxer engine into it.
i'm thinking maybe you're the idiot.
Old Apr 19, 2005
cg95660's Avatar
LOL I am surprised that this is even an issue. Go to how stuff works dot com. They have alot of cool diagrams and history on stuff you might not already know. The reason for the boxer is it looks like a boxer punching. But yes in the auto world flat is used more often. In this case in should have been used first thread. Boxer is an engine type and boxter is a car which is probly named after the motor(do not quote me). But to make it all square every one is right they are all similar engines. As for the use of that 2 stroke, I am sure it is extremely wide. And would not serve a purpose in a honda. I would belive that it would be used for generaters and super sized versions could be used to replace most other apps of diesel electric. I am just happy to see an efficient diesel. They have gotten a bad rep for alot of years but alot of what we do and need depends on them.
Old Apr 19, 2005
bradmanuwf's Avatar
Eat s.h.i.t Varmin and Hurts2bStock. you retards. giving me bad rep for something I was right about. I hope you two burn in hell! c.o.c.k juggling thunder c.u.n.t.s!
Old Apr 19, 2005
NoFriends's Avatar
waaaaaaah.....
Old Apr 19, 2005
varmin's Avatar
hmm, i gave you bad rep for calling people names without due cause. it seems like i was justified...
Old Apr 19, 2005
varmin's Avatar
and way to go, claiming a win in the flamewar from one person's post. the point still stands, the guy said boxster when he should have said boxer (or flat-six even, which he ALSO did not). noFriends was clarifying that point, like the troll he is. me, i just like to argue, hell, i sold my civic, i'm just here to stir up trouble now. go ahead, burn me bad, it might make me cry.
