Driving low on gas
Old Mar 9, 2005
LowRYda03ex's Avatar
LowRYda03ex is an unknown quantity at this point
Driving low on gas
I havent had a job for a while because of the boxing and baseball seasons, so my funds are low. Because of this I find myself constantly driving on almost empty, sometime below. Is this bad for the car at all? or does it not really matter
Old Mar 9, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
I do the same, they say you can get **** in your fuel lines, from the bottom of the tank though
Old Mar 9, 2005
CivicsRdBest's Avatar
not really, I mean, it all goes into the same place anyway... you just run the danger of running out.
Old Mar 9, 2005
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
yea and startin up ur car in 20 degrees weather with the light on is bad...fill up ur tank if u can, i kno i cant lol
Old Mar 9, 2005
nickm748's Avatar
yea i herd its only bad if its really cold out
Old Mar 9, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
Most newer vehicles depend on the fuel in the tank to help keep the fuel pump cool. The lower your run the vehicle, the hotter the fuel pump can get. Over an extended period of doing this, you would be more prone to a fuel pump failure. We see a lot of it on GM pickups.
Old Mar 9, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
running out of gas is really really bad for your fuel pump, also when its cold out condesation will form on the inside of the tank if your low on gas
Old Mar 9, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
u could have premature fuel pump failure..it will just burn up, because there is no gas to keep it cool
Old Mar 9, 2005
Al Gore FTW's Avatar
jdmtytedoridori
yeah, fuel pump failure is what i have always heard. i just fill it up and run it till like 30 miles after the light comes on. then fill up again.
Old Mar 9, 2005
Jrfish007's Avatar
That's what I was htinking. But I have yet to hear of a fuel pump going bad on a stock Honda. I'm not saying it hasn't, it just seems to be a better built pump I guess
Old Mar 9, 2005
Broken Road......
Probably is higher quality all around on the import side. We do a ton of domestic fuel pumps every year, GM being the most prevalent.
Old Mar 9, 2005
Jrfish007's Avatar
I have a Chevy truck... But it only has 46k on it and it's an '88
Old Mar 10, 2005
wow, good think i found out about this stuff now rather than later. Thanks for the input
Old Mar 10, 2005
skipbarber's Avatar
i find myself driving with the light on all the time
Xuhme
21
Aug 7, 2023 03:40 PM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
