eclipse gsx highway
Boosted Auto Sedan Project In Progress
eclipse gsx highway
ok guys i was just wondering why everone always says that all wheel drive cars are bad for highway racing is this true if so why thanx yall
Originally Posted by 02sleeper
wait it just cause thier heavier thats it i thought it had some thing to do with the four wheel drive
ok ill explain it very simply, engine with 400hp would rather turn just the tranny axles and 2 wheels if you add a drive shaft another differential and two more wheels the engine is kind of being robbed of the power so put a 300whp front wheel drive car for example: civic and a 400whp gsx chances are that the civic will hang with the gsx on the highway.
awd is fast from a standstill, but after a certain point it slows down a lot.. i used to have a subaru legacy AWD and when i would race my friends fwd cars i would take them off the line really well but after about 70 they would just fly past me and there was nothing i could do.
gotcha but over all a high horsepower 92 gsx can move on the high way right
FWD GS-T vs AWD GSX from a freeway roll, both stock, with the same horsepower, the FWD GS-T will pull.
AWD has greater power loss from the engine to the wheels than a FWD car.
also, in general, an AWD car that can run say a 14.0 in the 1/4 mile, will run more like a 14.5 car on the freeway from a roll.
gotcha guys thanx its just kinda of hard to get traction with a fwd car off the line and thats where the gsx kills it like at the strip the gsx will all ways win do to the take off and when i say the i mean against a car with similar horse power. plus all the pro racers yous the gsx as there set up but anyways thanx for the help guys
ok i did it i bought the turbo kit for my civic and i bought a 1995 mitsu gsx off cars.com its silver and hot. now i have enough money to swap the motor in the gsx but i was just wondering should i just go that route alot of people says its a way better motor but the 7 bolt motor i have makes 210 v.s. 190 it the 6 bolt so if i stay with the 7 bolt how much work would i have to put in it. and also no matter if i swap or not i want to build the motor inside and out.
dlg1985
Jul 23, 2017 10:03 PM
beanhead
Sep 24, 2015 12:04 PM
