Changing Sedan Tail Lights
Old Jan 29, 2005
Victorious's Avatar
Victorious will become famous soon enoughVictorious will become famous soon enough
I spent countless hours doing this simple job before I realized that you must remove the bumper in order to replace the tail lights on the outside part of the car. This is due to the brackets that are attached to the bottom of the tail lights that prevent you from just pulling out the lights after removing the 3 bolts.
Just wanted to save some of your time if you guys are planning to change your sedan tail lights in the future.
Old Jan 29, 2005
dirtySAMURAI's Avatar
I log in from time to time
if you searched on 7thgen, you would have found this information out already
Old Jan 29, 2005
Caucasian.Asian's Avatar
never tried to take them out, but yeah, i'm sure i could of found the info on here
Old Jan 29, 2005
Victorious's Avatar
No I tried searching first and I couldn't find anything about it.
Maybe I just didn't enter the right key words though..
Old Jan 29, 2005
http://www.7thgencivic.com/forums/sh...n+light+remove
second post
its ok, we can't expect n00bs to know EVERYTHING lol
Old Jan 29, 2005
doubledeuce2k2's Avatar
^^^ did mine without removing the rear bumper back in the day.
but that's ok
i also have smallish arms that fit up there OK
Old Jan 29, 2005
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
^^^ um yeah, i didnt have to remove my bumper, and i did my taillights twice
Old Jan 29, 2005
mexinaction's Avatar
i didnt have to remove mine either, all you do is just crawl underneath with a ratchet and you are done
Old Jan 29, 2005
hotrodcivic2004's Avatar
my civic has no boost
anyone put sedan lights on a coupe?
Old Jan 29, 2005
wtf kind of a retarded question is that?
Old Jan 29, 2005
ravolutionazx's Avatar
ravolutionazx has a little shameless behaviour in the past
uhm.,.stop smoking that crack
Old Jan 29, 2005
manahoonie's Avatar
trunk angle is different, same with outside. all angles are different. won't work without some good modding.
Old Jan 29, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
heres a pic from my tails removal.. it shows both ways the tails will end up.. you dont HAVE to remove the bumper.. but it keeps you from breaking the lil pegs off.. you can undo the two clips on the inside and push the bumper down and that does the same as removing it
Old Jan 30, 2005
kenji4862's Avatar
kenji4862 is an unknown quantity at this point
Did the same.. spent a long time trying to take a short cut... but in the end.. removed bumper.
Old Jan 30, 2005
i broke the peg on one side, but not the other. i was a little impatient yanking on it i guess.
Old Jan 30, 2005
S2000man01's Avatar
O RLY
yay
Poopies
Apr 20, 2017 11:36 PM
Erndog81
Oct 31, 2015 03:01 PM
shaejb15
Apr 12, 2015 11:38 AM
fordfocussucks
Nov 6, 2001 03:16 PM
