Was: My D17 Epiphany--Now: Motor/Turbo Reliability
Old Dec 2, 2004
sleekcivic2004's Avatar
sleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nice
Quote:
Originally Posted by aznboysrfr
but we know how reliable turbos are in d17's. just ask the many who have sold their kits...
sleekcivic2004:
Turbo's are as reliable on d17's as any other motor. All it takes is planning, research, balance, and common sense. Do your research and talk to people (shops, honda techs (or techs in general for non-honda), mechanics). If a car is unreliable because of a turbo it caused from lack of patience/parts(availability)/money. Kids, do your research, be patient and save your money to get the parts you need. Have them made if necessary; yes I know it costs more money, but I am on the subject of being reliable. I have had custom vehicles since I was 16. I have got ahead of myself, when I was younger, and not planned/researed things out and what has been the end product? Unreliability!
I'm not pin pointing anybody out. I just thought this was a good quote to offer my 2 cents. Take it or leave it.
Last edited by sleekcivic2004; Dec 2, 2004 at 12:57 PM. Reason: Couldn't tell where my post started
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I fail to believe that turbos on a d17 are as reliable as any other motor. if you put a turbo on an n/a motor it puts lots of stress on the motor that it was not made for. 8 or 9 psi are what some of the people on here are running and they have problems.
there are things you can't plan for with a turbo ... you could have your boost set at 6 psi and under bad circumstances, may spike to 20 psi and blow your motor.
a turbo d17 @ 9 psi is going to be a lot less reliable than a stock evo, for example.
research? yes, a lot of people do this. waiting for good parts? I don't know about that. if you're going to wait for good parts, you might as well just wait til you have about $15k saved up, then build your block and head to withstand 15 psi. then let's move to the axles, clutch, transmission. 15 psi and you're gonna break your axles after enough hard launches.
maybe if you run 5 psi and no more (on stock internals), it will be reliable, but who buys a turbo and runs only 5 psi?
Old Dec 2, 2004
At the moment I run only 5 psi and have 151hp. And I was talking about building a car that is reliable. Not a reliable race car....that doesn't exist. All you can build it where it will withstand a few runs if you are wanting to win or attempt to.
Old Dec 2, 2004
nindoo's Avatar
Why is my vagina bleeding?
Can you buy forged psitons and connecting rods for d17's, I think that would help our engine in terms of durability in a turbo setting. I'm just shooting info, I'm not sure if it would help.
Old Dec 2, 2004
I know of 2 companies on the pistons. I can't recall the names off hand at the moment but i'll will post them soon. On the rods I'm not positive, but I could definately find out.
Old Dec 2, 2004
nindoo's Avatar
I guess If we replaced the internals we could run a crazy amount of boost. To control boost do you need to have a wastegate?
Old Dec 2, 2004
cdmx's Avatar
You cant compare a non turbo charged car to a factory turbo charged car...
Old Dec 2, 2004
Yes, you need a wastegate whether it be internal or external. In order to use a boost controller though it needs to be external.
Old Dec 2, 2004
cdmx's Avatar
What? I never knew this
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
EXACTLY my point. if you read his first statement, he says "Turbo's are as reliable on d17's as any other motor."
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
um... I had a turbo w/ an internal wastegate and my boost controller worked ...
Old Dec 2, 2004
cdmx's Avatar
Yea i read that too, but i took from it that he meant other motors that are not factory turbocharged.
right??
But then again no one is ever 100 %
Old Dec 2, 2004
cdmx's Avatar
I was about to say...WTF is going on here...
this contradicts everything that i have read?? or haven't read??
Old Dec 2, 2004
cdmx's Avatar
You just lost major respect points
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
right??
if that is the case, then it is still not entirely true. some motors were built stronger than others when running a turbo. for example, a k20 turbo can handle more boost than a b20 turbo
Old Dec 2, 2004
cdmx's Avatar
Oh yea also there's a FAQ somewhere that has all those companies listed to get internals from
Old Dec 2, 2004
cdmx's Avatar
^^ if that is the case, then it is still not entirely true. some motors were built stronger than others when running a turbo. for example, a k20 turbo can handle more boost than a b20 turbo
We just love to pick at things here
I get what he generally meant though.....
Old Dec 2, 2004
cdmx's Avatar
haha thats a funny edit
" Last edited by sleekcivic2004 : 1 Hour Ago at 01:57 PM. Reason: Couldn't tell where my post started"
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Old Dec 2, 2004
nindoo's Avatar
Cant we all just be friends and help each other modify our cars.
Old Dec 2, 2004
Like I told cdmx.....I was sure I would stand corrected on the wastegate/controller issue if I was wrong....and I am. It happens.
Old Dec 2, 2004
cdmx's Avatar
yea, thats what this site is here for
but to talk about how things work is another story, it seems like no one is ever 100% and someone dissaproves this and that...I say everyones experiences are different. Afterall no engine is Exactly the same.
And i hope my experiences while boosting soon will be in a positve way
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hope you're not planning on going sf
Old Dec 2, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
dude just about every turbo out there has a internal flapper style wastegate, externals are usually an upgrade..because they can be controlled BETTER...i personally know that all digital boost controllers have a switch for selecting external or internal wastegate, so that statement is false
Old Dec 2, 2004
robo1040's Avatar
either that or HKS and Greddy have been lying alllllll these years
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ haha nice sig
Old Dec 2, 2004
robo1040's Avatar
mine? lol
Old Dec 2, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yup.
Old Dec 2, 2004
Trigun's Avatar
Trigun is an unknown quantity at this point
All I can is that I have always been a Honda person. I mod my civic because it makes me happy even though my girl wishes I had a less expensive hobby..lol. Honestly though, if the D17 that I have under my hood was made primarily for fuel economy, will working on the engine really make the engine faster or will it just ruin the engine since it wasn't built for racing?
Old Dec 2, 2004
cdmx's Avatar
No, custom
Ive decided to stretch out getting everything
But most everything will be bought in janurary.
Fuel system stuff and tuning will be my only issues and having to find a proper place to tune and what all to have for a perfectly working fuel system that wont cost me half the turbo kit.
