maitence question
Old Nov 28, 2004
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
maitence question
im thinking about now brining my ciivc in for the 15000 checkup thing, i already hvae 15300 on the car. i was wondering what i would need to do if i wanted to do the maintence myself? is it just changing the oil and air filter? And is it a bad idea not to bring it in for maitence? i know they do brake checks and alignment checks... i just dont feel like paying 250 bux for them to change my oil
Old Nov 28, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
i dont know for sure..but if u change the oil yourself you have to some how get the maintence light to turn off..the maintenence light comes on whenever an oil change is coming up or needed
Old Nov 28, 2004
ACURAwerx's Avatar
my maitenence light never comes on when i need an oil change, it only comes on when i need a check up! and it never came on this time.... it only came on when i need the 8000 mile or wahtever service!!!!!!!!! do u think ill be fine if i just change the oil (which i always change myself anyways) and the air filter?
Old Nov 28, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
My car has 75k miles on it and all i've done is oil changes and the airfilter. No problems whatsoever. All they really do is check and top off fluids and do alignments and balancing. When you get to like 60k I think they change tranny fluid and stuff like that. There are instructions in your car manual for turning off the maint. required light.
Old Nov 28, 2004
robbclark1's Avatar
Retired suspension supermod.
at 15k just change your oil. When you get to 30k, lube your doors, change your air filter, tranny fluid change, coolant change, and check your microfilter (if you have one). Brake fluid might be good too.
Old Nov 28, 2004
ACURAwerx's Avatar
awesome, so are all the honda maitenence services pretty much just a waste of money?
Old Nov 28, 2004
civicvtec1ps's Avatar
Search and Learn
Yup.
Old Nov 28, 2004
dchalifoux7's Avatar
dchalifoux7 is an unknown quantity at this point
The maint required light turns off easy... I think you just turn the key on notch and then hold the mileage button down until that mo fo shuts off... mine comes on every 7,000 miles or 7,500... I took my car in for all the maintenence stuff till 75000 miles. That is when my warranty went out... NOw I will do it myself. It is my first new car and didn't want ANYTHING to go wrong... I was afraid if something went wrong they wouldn't help me out or fix my ride...
Old Nov 28, 2004
YUL's Avatar
YUL
YUL has a spectacular aura aboutYUL has a spectacular aura about
yea....the maintenance program is a bit of a scam so the dealership can make $$.
I do all my stuff, oil change, air filter change, tire rotation and all that
Old Nov 28, 2004
ACURAwerx's Avatar
okay cool, thanks guys! however if i dont do their services, and say something goes wrong with my car, will the warranty still be good?
Old Nov 28, 2004
skipbarber's Avatar
yes, so long as its a manufacturing defect. if you screw something up, or neglect something, its your fault.
Old Nov 28, 2004
TemjinX2's Avatar
i dont get why your dealership is charging you $250 for the 15k check. My dealership just charged me $65 and that was a waste of money. All they do at 15k, is change oil, rotate tires and inspect your brakes, alignment and air pressure in your tires. With just 15k everything should be ok on your car unless you abuse your car.
Old Nov 29, 2004
exclusive_vtec's Avatar
yep^
i had my 15k at the dealer as well.. changed oil rotated tires.. inspected brakers yada yada yada.. waste of money
Old Nov 29, 2004
Mystic3030's Avatar
If you look in your owners manual it says what they recomend you do at each service point.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
