i need $30 right now!
Old Nov 5, 2004
  #31
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
How Do U Remove The 2 Big Fat Philips Screw???? You Know.. The 1 That Attaches To The Rotor?
Old Nov 5, 2004
  #32
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
haven't done it on the 'vic yet myself, but from what i hear, WD-40, let it sit, then use a No. 3 phillips head bit to loosen.
Old Nov 5, 2004
  #33
tripledoublegs's Avatar
Euro-Spec
I just got my paycheck, so I'll be getting the rotors tomorrow, since I had my hawks in the garage for 2 weeks now
Old Nov 5, 2004
  #34
Skunk2ner's Avatar
sweet deal man. good luck.
Old Nov 5, 2004
  #35
K20me's Avatar
Okay, that sounded like a legitimate question so i'll give you a legitimate answer. If the screws are stuck on the rotor and you can't get it off with just a Phillips screwdriver: 1. Stick the Phillips screwdriver into one screw, 2. then use a hammer and hit the top of the screwdriver a number of times, 3. Hitting it with the hammer will loosen the screw and you'll be able to get it off with no other problems. Do the same with the other screw. I have done this numerous times and it has not damaged the rotors.
See, I CAN be a nice guy if you ask REAL questions.
Old Nov 5, 2004
  #36
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
You use an impact screwdriver. Basically, it has a phillips tip on it, then you hit the other head with a hammer. Works great. If you don't you usually strip the screws out, since the heat and water rusts them stuck.
Trust me, get the tool. I had to drill one out this weekend and it was a pain.
