10,000 Miles Check
Old Apr 15, 2004
civicvtec1ps's Avatar
Search and Learn
Thumbs up 10,000 Miles Check
Tire rotation.
While beneficial in many ways, tire rotation cannot correct mechanical problems or problems caused by incorrect tire inflation.
* On front wheel drive cars, rotate the tires in a forward cross pattern (fig. A) or the alternative X pattern (fig. B)
* On rear wheel or four wheel drive vehicles, rotate the tires in a rearward cross pattern (fig. C) or the alternative X pattern (fig. B)
* If you car has directional wheels or tires, rotate them as shown in fig D.
* If you car has non-directional tires that are a different size from front to rear, rotate them as shown in fig. E.
Tire rotation is an important part of vehicle maintenance. Rotating your high performance tires every 3,000 to 5,000 miles as recommended can provide performance advantages, even out tire wear and preserve balanced handling and traction of the tires.
Oil change.
Change oil every 3000 miles regardless what Honda says.
Check all fluids.
Check Brakes.
Check Windshield Wipers
Reset the "maintenance req'd" light.
To reset it =
Hold down the trip/odometer button on the gauge cluster.
Don't let it go
Then put key in ignition and turn to the position #2 or "on" position.
When in that position look at the maintenice lightwhen it goses out it is reset.
Release the button. Then start the car.
I also checked Tie Rod boot.
Driver Side boot was torned for over 4 months.
I am too lazy to change it..
Look at Rear sway bar Endlinks.
Front Sway bar Endlinks.
Clean Wheels.
In and Out.
Check Tire Pressure.
I am running 35PSI.
Dealer Charges $150 to $200 for this.
You can do this at home.
Old Apr 15, 2004
abmerop18's Avatar
Jam out with your clam out.
nice info man. how do you clean the inside of the tires good? i always get all this crap on the inside of mine. i think it is melted rubber that just sticks in tiny little pieces to the inner lip on the rim
Old Apr 15, 2004
Mr.Modify's Avatar
i needa clean my damm rims...in and out but good post nonetheless ...i will be DIY
Old Apr 15, 2004
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
good info
Old Apr 15, 2004
Fast02
Guest
Posts: n/a
Great pics!! Thanks for the info!!! You're always so helpful!
Old Apr 16, 2004
Search and Learn
No Problemo.
Thanks for looking.
abmerop18
I just take wheels off then use Wet Towel to clean wheels.
Nothing works better. IMO
Old Apr 16, 2004
AR's Avatar
AR
e-married to daydreamer
my '02 is still at 8k
Old Apr 16, 2004
Jodster's Avatar
Post Whore General
Nice man.
Old Apr 16, 2004
Gecko's Avatar
good info
Old Apr 16, 2004
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Damn someone doesnt drive much. I have 41,xxx on my 01.
Nice DIY.
Old Apr 16, 2004
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
Nice DIY.
im actually takin my 02 for the 40k check up today.. i drive too much
Old Apr 16, 2004
Milamber's Avatar
I hate people.
Milamber will become famous soon enough
Damn, thats no miles at all
I have an '03, with 18k
I like driving it
Old Apr 18, 2004
Titleist71's Avatar
I use 3M polish that u would use on your car to buff it. It is clearcoat safe and it gets all the grit off your rims!!!! Looks brand new!
Old Apr 18, 2004
meth's Avatar
meth is an unknown quantity at this point
my 02' just broke 10K too... i go low miles as well.
Old Apr 18, 2004
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
I'm up at around 26k and was going to rotate my tires today, but when I was lifting the first wheel on the jack, i noticed that even though the jack was going higher and higher, the tire was still planted on the ground... WHen i looked at it from the front, the jacked side was probably 15 degrees higher. I'm not sure if i'm just quitting too early, but my old car (ford taurus) didn't require it to be lifted so high and I'm afraid trying to forcefully jack it higher (I used one of those sturdier jacks on wheels you can buy at a car parts store) might damage the frame. Am I just being a whimp? or could there be something messed up with my suspension?
Old Apr 18, 2004
thomusvoo's Avatar
Newbie Member
when is the best time to change the air filters?
10 k ??
15k ?
20k?
Old Apr 18, 2004
zen_master's Avatar
just do it now and change it with K&N drop air filter..
and then....sit tight....u won't have to change it anymore..
Old Apr 18, 2004
thomusvoo's Avatar
Newbie Member
never change it?
wth!?!?
so i guess dirt just fly through
lol
Old Apr 18, 2004
zen_master's Avatar
what i mean, u just have to clean the filter with the charger kit..
but u don't have to change the filter no more.....that's why u use K&N
Old Apr 18, 2004
thomusvoo's Avatar
Newbie Member
whoa!!!!!^^^
does the K&N make your car louder for your car?
because i dont want that.
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
