Honda Recalls 440000 2002 Civics
Honda > Nissan
Rep Power: 0 Honda Recalls 440000 2002 Civics
Just found this out, as of FEB 24, 2004 Honda will begin recalling 440000 2002 Civics this month due to the low-beam terminal on the head light wire harness can overheat which will cause our low beams to fail.
http://www-odi.nhtsa.dot.gov/cars/pr...odel_year=2002
Make: HONDA
Model: CIVIC
Year: 2002
Recall Number: 04V086000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE LOW-BEAM TERMINAL ON THE HEAD LIGHT WIRE HARNESS CAN OVERHEAT AND COULD CAUSE THE LOW BEAMS TO FAIL WITHOUT WARNING.
Consequence:
AN UNEXPECTED LOSS OF LOW BEAMS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE HEAD LIGHT SWITCH AND COUPLER FOR SIGNS OF HEAT DAMAGE. IF HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE SWITCH AND COUPLER. IF NO HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE HEAD LIGHT SWITCH AND ONE MATING PIN IN THE COUPLER. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING MARCH 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Make: HONDA
Model: CIVIC
Year: 2002
Summary:
Consequence:
Remedy:
Notes:
Rep Power: 560 dont forget about:
Summary:
CERTAIN SEDANS AND COUPES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 209, "SEAT BELT ASSEMBLIES." CERTAIN REAR SEAT BELT BUCKLES WERE IMPROPERLY MANUFACTURED.
Summary:
VEHICLE DESCRIPTION: SEDANS AND COUPES. THE HOSE CLAMPS ON THE FILLER NECK TUBE HAVE INSUFFICIENT CLAMPING FORCE.
Consequence:
IN A COLLISION, THE TUBE COULD DISCONNECT FROM THE FUEL TANK, RESULTING IN FUEL LEAKAGE. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Summary:
ON CERTAIN SEDANS, A SMALL AMOUNT OF WATER MAY HAVE BEEN LEFT IN THE FUEL PUMP ELECTRICAL CONNECTOR AFTER TESTING. THIS RESIDUAL WATER COULD CAUSE THE FUEL PUMP TO FAIL DUE TO CORROSION.
Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. DURING THE ASSEMBLY PROCESS, THE AIR CLEANER BOX COVER MAY HAVE BEEN DAMAGED, AND A BROKEN PLASTIC PIECE COULD TRAVEL INTO THE INTAKE CHAMBER.
Summary:
Summary:
Consequence:
Summary:
Summary:
Jap-Euro Fusion
Rep Power: 401 So what do they do with cleared headlights? They still gotta fix them if the harnesses are unmodified right?
Rep Power: 0 Originally posted by Jhonda
NOW I THINK YOU SHOULD LAY OFF THE FORD FOCUS
just my opinion though
and I thought honda didn't ever have any problems
Rep Power: 0 Summary:
Consequence:
Wow thats sounds like the pinto
Consequence:
Jam out with your clam out.
1 Post
Rep Power: 488 if i have an 02 and cleared headlights and stock wattage xenon lights (65w) will that cause a problem with the fix? should i swap the stock bulbs back in if they call in my car?
A descendant of 2k1civic.com
1 Post
Rep Power: 336 Originally posted by gearbox
One of my sylvania bulbs blew a while back and I've got an 02. Is it something we can check for ourselves?
Yup, i'm an A$$hole.
Rep Power: 305 I believe if they recall the part, regardless of headlight modifications, as long as the harness plug that they are recalling hasnt been modified, it should get replaced. Just call your Honda dealer and ask.
Rep Power: 360 Originally posted by Mystic3030
JDM wannabe
Rep Power: 0 Originally posted by PbFoot
Summary:
Consequence:
Summary:
Consequence:
Since 2002 Baby!
Rep Power: 309 Does this count if i'm over my miles? Cause this could help me and my headlights burning out every 4 months. Keep us updated. I made an appointment for tomorrow, but was going to cancel, cause I have no more warranty. For this very discussion.
Rep Power: 0 Since were on the topic of quality......I think that Honda quality has gone down anyone else think that????? Compare previous models to our current model, the quality is lackin so many recalls I've had so many things done to my vehicle I have a library of dealer invoices in my possession. Our interiors are now cheap plastic, before they were all vinyl, our alternators are made by mitsubishi, our ignition systems (dont flame if its no the ignition but i know something electrical is) are made by the German company Siemens.....kinda seems to me like im drivin around a "Frankenstein" For this reason the next car I buy will be a japanese MADE IN JAPAN or european MADE IN GERMANY (prefferably) vehicle shipped on a boat...........<bow>G35 or <bow>M3 here i come
