Acceleration....
Old Nov 25, 2003
BlackIce's Avatar
BlackIce is an unknown quantity at this point
Thumbs up Acceleration....
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
* Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture for nitromethane the flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After ½ way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to light!
* Including the burnout the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective: You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere
1320 foot long race course. That folks, is acceleration.
Old Nov 25, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Wow! Good post. I leaned something new.
I'll just go outside and cry in my civic now.....
Old Nov 25, 2003
00celicagts6spd's Avatar
ha ha that was some good stuff. lol 200 mph head start. lol
Old Nov 25, 2003
ImPulse's Avatar
"run costs an estimated $1,000.00 per second."
ouch... How much $ do they get?
Old Nov 25, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
That's pretty quick. . . .
I wonder how fast an aircraft carrier catapult could get that thing going. They can hurl a 45,000 lb plane from 0-165 mph in 2 seconds, after all.
Old Nov 25, 2003
robbclark1's Avatar
Retired suspension supermod.
nice....
Old Nov 25, 2003
Ichiban's Avatar
Ichiban is an unknown quantity at this point
I would probably pee my pants at 8Gs.
Old Nov 25, 2003
gotti's Avatar
i dont think id pee my pants....
Old Nov 25, 2003
Yukonart's Avatar
I think, physically, it would be very difficult to pee one's pants at 8g's.
Old Nov 25, 2003
NoFriends's Avatar
I like ruining your threads.
im amazed they have any sort of traction to do all that. I know their tires are huge, but damn.
Old Nov 26, 2003
BlackIce's Avatar
I know what you mean, it seems the tire would just rip apart or blow up off the rim. I have seen slow motion video of what happens with the tire and rim. It just shows how much power they have, when you see the rim spining and the tire not moving but flexing and expanding then eventually giving. Friggn' amazing...
Old Nov 26, 2003
ImPulse's Avatar
tires go like 10 ft in the air, haha!
Old Nov 26, 2003
C2i0v0i1C's Avatar
SuperMODrizd
and that ladies and gentleman IS acceleration......and that IS one heck of a 1/4 mile time.....and that IS one heck of a 1/4 mph
Old Nov 26, 2003
NoFriends's Avatar
yeah ive seen it too. the tire gets "twirls" in the rubber as the wheel starts to spin. Then as the tires get up to speed they expand upward becoming very narrow. Its so trippy to watch, slow mo shows some crazy ****. Like watching a golfball being hit, you think the ball is solid, but in slow-mo, it actualy compresses into a "D" shape, then rockets off the club head.
Old Nov 26, 2003
NoFriends's Avatar
another little golf fact for you... the entire time the ball is in contact with your club in an 18 hole round is less then a blink of an eye.
Old Dec 1, 2003
BlackIce's Avatar
I will try not to blink next time I play golf then....
