my experiance at jiffy lube
Old Nov 24, 2003
kempster's Avatar
kempster will become famous soon enoughkempster will become famous soon enough
Well i was in desperate need of an oil change and i had some free time so i went out looking for a place that would do it. After going to all the places by me and them all saying no because my exhaust and car was to low, i headed for jiffy lube. At first it seemed like it was going to be another no, but than they decided to try something, as i was going to pull in they were going to lift up the front part of the body by hand from the wheel wells. to my surprise it worked, no stractching or nothing, so they changed my oil.
Then i went to get my car out and everything possibl went wrong. We went to get the car out the same way by lifting up the front, but as i was pulling foward the front clamp on my exhaust got caught on the 'gated' front where the change the oil. then as we tried to get it unstuck, the exhaust got pushed back and sort of took my back bumper with it on the passenger side. at this time the guys go downstairs and get under my car and undo my exhaust, i unscrew my backbumber, put it into place and screw it in.
after about 20 min one of the guysstarts pulling down on the back of my exhaust, which lifts the front part of it up high enough to back the car up. now after the guys get new clamps for the exhaust, put the exhaust back on we tried backing it out the same way i pulled in and thank god that worked. My 15 min oil change turned into over a 1 hour project.
i guess now i should learn how to change my own oil;
Old Nov 24, 2003
You should learn how to do it yourself if the car is so low. Most places won't touch it anyway because of liability. At least you made out okay.
Old Nov 24, 2003
CaShMoneyBlng's Avatar
CaShMoneyBlng is an unknown quantity at this point
Jiffy Lube always seems to screw up when I try them. I took it there last week because I needed a change and had no time. Dropped it off, I was in and out in 15min. Good deal right? No, look at the invoice later and they only put 3 quarts of oil in, and when I went to check my oil they didn't even screw the oil cap in all the way and there was oil all over my valve cover.....I hate those guys.
Old Nov 24, 2003
Da1lyDr1ver's Avatar
yup, never go to jiffy lube. where i live jiffy lube employs these kids that have no experience or are too young to drive.
when i brought in my old car they over tightened my drain plug and stripped the threads cuz they put the bolt in crooked.
then when my friend went there with his caddallic, they drove it off the ramp things that they do the oil changes on.
Old Nov 24, 2003
Bellz's Avatar
Re: my experiance at jiffy lube
Originally posted by kempster
...After going to all the places by me and them all saying no because my exhaust and car was to low, i headed for jiffy lube
....lift up the front part of the body by hand from the wheel wells.
... the front clamp on my exhaust got caught on the 'gated' front where the change the oil.
...the exhaust got pushed back and sort of took my back bumper with it on the passenger side.
It's stories like this that convinces me that I made the right decision to NOT lower my car. lease:
And if you think you'll be able to do better at home, consider this...
How are you gonna get underneath it to unscrew the plug or change the filter? It is lowered after all. You think it'll go up ramps? Wrong. I have a set of ramps and even my unlowered civic can't get up them without some helper boards to make the angle less steep.
All I can say is good luck!
Old Nov 24, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
ur car is not even that low..thanks for the warning..
Old Nov 24, 2003
mphole's Avatar
Rota C10 Coming Soon.
mphole is an unknown quantity at this point
jiffy lube's too expensive for me.
Old Nov 24, 2003
mk32382's Avatar
mk32382 is an unknown quantity at this point
Re: Re: my experiance at jiffy lube
A jack. and jackstands. simple as that...
Old Nov 24, 2003
kempster's Avatar
Re: Re: Re: my experiance at jiffy lube
thats what i'm hoping works now
i'm about 2 inches lower than in my members rides, i don't have new pics up
Old Nov 25, 2003
cryption's Avatar
2003 Nissan Frontier
thats wierd because how they do oil changes out here its a pit at the place. They don't jack the car up or anything, you just drive it over this hole dug in the ground and they work on it like that .. you can even sit in your car while they do it.
Old Nov 25, 2003
cryption's Avatar
sorry double post
Old Nov 25, 2003
jjj784's Avatar
jjj784 is an unknown quantity at this point
bring your own 2x4's to make it up!
Old Nov 25, 2003
kempster's Avatar
thats what it was like at the place i went to put there is like a lip to it that sticks above the ground
Old Nov 25, 2003
acidbaby's Avatar
The Beez Kneez
that is the exact reason that all the other shops didnt do it..
do it yourself takes about 15 min.
Old Nov 25, 2003
Maddog_Enigma's Avatar
Maddog_Enigma is an unknown quantity at this point
oh boy...
Old Nov 25, 2003
slicksivik's Avatar
what places have the inground thing where u drive upto, cuz i hate taking it to places cuz they always mess up. one place left some oil on my fender, stupid people and antoher scratched my kit on the bottom but u cant see it. its not even lowered either. when i do lower it, its gonna be a pain in the butt to get up. should i take it to a porcshe dealership to get it done? they always work with lowered cars. any ideas.
Old Nov 25, 2003
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Porsche will laugh at you. Why don't you dig a hole in your yard and drive it over that? Or get the smurfs to change your oil?
Old Nov 25, 2003
Gryphin's Avatar
00 Hatchback Owner
sucks for your muffler bro.. and like cryption said, we have wholes around here, you just drive up the little drive way about a 1 inch bump then over the little hill and park in the middle of the shop...
Old Nov 25, 2003
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
I prefer to change mine myself. I guess it's cause im a DIY guy when possible.
Plus i dont trust anyone with my car except me.
Old Nov 25, 2003
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
This is just another prime example of why some people called them "Iffy Lube."
They've caused permanent damage to a car I used to own, problems stripping out drain plugs on in-law cars and KNBC-4 in Los Angeles recently ran an investigative story that showed how "Iffy Lube" was trying to push unnecessary sales/service on people. They obtained an internal memo showing that each store is supposed to make $68 sales on each car.
Unless you just can't make it to Vegas to gamble, don't go there.
Old Nov 25, 2003
dru106's Avatar
ThE CoRRupToR
You should buy some tools to do it urself thats what I did recently. I asked a lot of places to do oil change and they said no cuz my car is lowered wit bodykit. So this one place that said yes put in the wrong crappy oil and filter on . I was like thats it!!! Im gonna do it myself! All u need is a hydrolic floor jack and oil pan which shouldnt cost u more than $30.
Old Nov 25, 2003
ebound's Avatar
ebound is an unknown quantity at this point
15 minutes isnt a really good time for changing oil, unless you like vacuum it out of there. if you want every last single drop of the nasty oil out of the oil pan, give it like 30-45, or even more than that maybe. I suppose it all depends upon how much time you're willing to watch oil trickle...
Old Nov 26, 2003
cryption's Avatar
lol love your sig ebound .... mad props
Old Nov 26, 2003
civicdude's Avatar
Kempster why would you goto Jiffy Lube...Havent you heard all the horror stories from that place.....Never go there dood.
You should of went to Mavis, they would of did your oil change.
Old Nov 26, 2003
ExOrCizT's Avatar
ExOrCizT is an unknown quantity at this point
do it at sears... they jack the car up on one of them lifts...
Old Nov 26, 2003
94civicsedan's Avatar
94civicsedan is an unknown quantity at this point
Yeah I change my own oil bc Ive gone to walmart to do it, and it takes FOR-EV-ER. It only takes me less than a hour to do everything. THe only thing I hate doing is jackin up the car. I have to jack up one side at a time, and that takes a while for me. Its a bigger pain when I rotate my tires. I think im gonna get some extra jackstands for that.
Yeah I heard this trick you do when you have a lowered car. You roll your car onto some pieces of wood which makes ur car higher off the ground, and then you can jack it up. In auto last yr this guy had a lowered supra and it wouldnt fit over the lift so we had to liftthe car up and put the lift arms in place.
Old Nov 26, 2003
Okay, now proper english looks like this:
You should have gone to Mavis, they would have done your oil change.
Old Nov 26, 2003
01EMCVC's Avatar
01EMCVC is an unknown quantity at this point
i work at a quick lube type place,, ahh the benefits(free castrol syntec oil, tranny flushes and cooling system flushes as well as fuel sytem cleaning)
Old Nov 26, 2003
mk32382's Avatar
You can wrap a piece of **** in tinfoil, tie bows at the ends, and call it a holiday Tootsie Roll, but it is still a piece of ****.
Translation:
A n00b with good grammar is still a focking n00b. lease: Get yourself laid or something, paisan...
EDIT: I almost forgot...yeah, J-Lube DOES suck. My roommate used to work there. The still borns they hired got into all kinds of crazy, stupid kid ****. Hmm...let's see...a fire in the pits one time. Hmm...one time, this guy took his car in for the signature service or whatever, and his bike was still racked to the top. Well, this Josh kid, about 4 foot nothing, decides to take the shortcut way around to the front...through the car wash...with the bike still attached to the top. He guns it through, CRASH, bike is done for, whole roof of the car is all focked up. They had to cut the guy a check for about 3.5k to cover the damage to the car and another 1.5k for the bike. That sort of thing happened all the time, along with change falling out of shirt pockets into valve covers, caps not being tightened down, overcharging for filters etc. Don't EVER go there.
Old Nov 28, 2003
BausHaug's Avatar
I Am The Funky Monkey!!!
BausHaug is a jewel in the roughBausHaug is a jewel in the roughBausHaug is a jewel in the roughBausHaug is a jewel in the rough
I normally do it myself cause it makes me feel a little better when I try to maintain my baby by myself. The only time I had to take her in was when I had a CV boot problem, but that was covered under warranty. The next time I take her into a shop is when I drop the K20 in next year.
