General 10th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
It's all about the bass
Old May 1, 2019
Retta75's Avatar
Retta75 is an unknown quantity at this point
Question It's all about the bass
I just got 2019 Civic Touring on Monday and I've been playing with the sound settings but there doesn't seem to be much bass. I have the sound up, subwoofer as high as it goes, but still haven't noticed much change. What do you guys have your settings at? Or maybe cuz it'm streaming music from my iphone it's different? With 9 speakers and a sub I thought it would be louder/more bass.
Old May 1, 2019
Re: It's all about the bass
Research a bit, I think the sub isn't really a true subwoofer as most of us think of it, but more like a low range woofer
does regular and hd FM radio and XM radio sound any better or worse than your phone?
Are you using a cable with the phone? That's supposed to sound better than connecting the phone via bluetooth or wifi
Old May 1, 2019
Retta75's Avatar
No I wasn't using the cable. I'll try that next time. When I listened to Sirius, there was definitely more bass, so that's encouraging. I mean, the sound is crystal clear when I'm using the Bluetooth, there's just almost no bass. There was definitely a difference with Sirius. I didn't try listening to FM radio yet. Thanks for the tip.
Old May 1, 2019
Sounds like the car does not have a problem, your phone setup does
Old May 1, 2019
Retta75's Avatar
It's entirely possible. Maybe I need the volume turned up on my phone more, too.
Old May 3, 2019
GolNat's Avatar
Prelude Owner
If you are using the music app on the phone check your phone EQ settings. If they are on normal it has no bass and sucks. I think it is separate from other app settings but maybe not. Worth a try.
Go to:
Settings - Music - scroll down to EQ ( I keep mine on rock).
Old May 4, 2019
Retta75's Avatar
Go to:
wow thanks. I didn’t even know you could do that haha. I feel sheepish. The EQ was set to off. So I put bass booster on since I listen to all different kinds of music. I’ll test if out tomorrow.
Old May 4, 2019
Retta75's Avatar
So I tried it out, and also turned up the volume on my phone and I have BASS!! I'll play around with the other options but Bass booster seems to do the trick. Thanks again GolNat
Old May 4, 2019
GolNat's Avatar
Prelude Owner
Awesome. It's important to have good tunes while driving. I listen to all different types of music too and found the rock one to be the best balance. Really depends on the car though. In my Fit the rock offered the best balance for country, rock, rap, hip hop, metal, soul, dubstep and any other type of music that I might be in the mood for.
Old May 4, 2019
Retta75's Avatar
For sure. I gotta have good sound to go with the tunes. I'll check out the rock one and see how I like it
Old Jul 14, 2019
BobAlbright's Avatar
BobAlbright is an unknown quantity at this point
Little late getting to this thread, but thought I’d give you my two cents of info. Consider replacing all the speakers that came in the car from new. Car manufacturers generally put really rap speakers in their new cars. I bought a 19 Civic LX Hb a few months ago and just replaced all four factory speakers with Infinity speakers from Crutchfield. Around $50 each. Infinity speakers always have an excellent high end with nice imaging Another plus is they are very efficient. My head unit remains stock. Using the factory speakers, I was finding I was using mid 30’s on the digital readout..which peaks at 40. With the Infinity speakers..to get the same volume, my readout is in the mid 20’s. Amplifier therefore is not having to work so hard...lower distortion.
Also...and very important! Play with the front to rear fader. My experience is that I generally need to fade several notches towards the rear. Find the ideal sweet spot by moving your head forwards and backwards so as you feel the sound is all around you. Typically also s to bump the treble pretty close to max. Great Bass is fun, but it’s the high end that adds the detail, presence, and imaging. I might add the Infinity speakers have a considerably better high end over the factory speakers and the bass is a little deeper, but much tighter
Old Jul 14, 2019
What I've done in my 18 sport (non-touring) to get better sound is mess with the eq setting my my phone, too. Made a huge difference. I stream via Bluetooth almost exclusively, too. I also have my factory head unit settings to almost full bass (like 2 ticks from highest) about 2/3 highest setting mid, and about -1 or -2 ticks treble. Bass is acceptable, and overall sound is actually pretty good, considering I have a stock sound system with tweeters wired in (mine didn't come with tweeters, sub, or center channel like yours).
Old Jul 15, 2019
You will get better sound if you plug in rather than stream
Old Aug 15, 2019
constantin_md's Avatar
constantin_md is an unknown quantity at this point
You got lucky, because the Infinity speakers you bought have probably better Sensitivity(can produce more sound per watt input) than stock speakers.
This is very rare, because stock speakers are usually built of crap and very light materials which are easy to drive and have great Sensitivity.
Higher-end aftermarket speakers are usually built of better, heavier materials and are harder to drive (lower Sensitivity) so if you went with other Speaker model you could have spent a lot of money and time and had worse sound.
A much better and sure sound improvement is replacing the amp. Even the crap speakers in any car may sound great with a better aftermarket amp, but for doing it right you'd need an expensive Audio DSP (DIgital Signal Processor) also.
As for the OP , he asks for more bass a LC2i converter + an alpine PDX m6 ($260 on ebay, very power efficient) + any subwoofer found on craigslist (can always resell it if you won't like it) would give great results.
NoLeadEmSoMuch
Mar 20, 2008 08:55 PM
HondaLuver
31
Mar 11, 2007 03:15 PM
koreth
Aug 7, 2006 07:49 PM
IronFist
81
Sep 12, 2004 10:17 AM
