Install fest at Grey's on Fri. June 13th
hey grey, can you give me directions to your house from watertown or wellesley? just in case phil decides to come later and i cant follow him.
also, let me know if i need to bring anything particular. im bringing the springs/camber kit (obviously), wrench and wratchet sets. but i can also bring my jack stands and jack. anything else??
im gonna grab the beer on friday, but let me know if you got any preference.
DIY King
Carlsberg is allright. Basically anything, but domestic light beers. Thread Starter
heh...sounds good on the beer. i dont drink domestic, so its ALLL good.
im gonna try to find an autozone here, but im not sure if theres any around. you know of any up there by you? if theyre not expencive, maybe i should just buy a set since im gonna have to put stock springs back on later. and im sure im gonna drop my next car as well. hehehe
unless you have 4 jackstands, ill bring my 2. that way we can lift the car completely and not have to go to the hassle of up, down, up, down.
as far as your address, no...you didnt give me that. PM me and i can do the mapQuest thing.
DIY King
Yes it is good.
There's an Autozone close to me. That's not a problem. We'de just have to finish before 5:00PM 'cause I think that's when they close. I can't rent them myself because I shouldn't be using my credit card. I'm maxed out.
As for the idle problem. I guess we'll take a look at it. I think it's the throttle body personally. The TPS could have gotten messed up. We can check that with my Voltmeter. The throttle body may just need to be cleaned. We'll see...
Spring compressor rental is free at the autozones here.....you give them a $20 deposit, and when you bring the compressor back, you get your $20 back. And Phil, the "somewhere" idea of your timing belt came from me, remember?
i just rented the spring compressor and a pitman arm puller tool, so we should be all set to go.
"rented" i should say, since the dude couldnt figure out how to rent them, so i bought it and he said i should just return it when im done. hahahaha...so i guess its free in NJ also.
coronas w/ lime sound good to me. hope you have a cooler cause i dont have any room in my trunk for one anymore. haha
see you all on friday if i dont get to log on tomorrow (might be a heavy day at work)
Corona w/ lime.......... yummmmm
Yeah, I be dere.
and Pill's idle? lets see, here are the guesses:
Brandon: timing belt (100% disagree, there would be no power at all if this was the case)
Meehow: TPS or throttle body (could be TPS, very easy to check, but I doubt it since they don't just "go" on idle, they "go" on all voltages, throttle body, no, cause it would only be acting up if he turned the A/C on and not when it's off)
Me: Mentioned before: Vacuum leaks cause misfires at idle, bad plugs, bad wires, bad cap and rotor, clogged injector, bad fuel pump....
Don't forget our wonderful code: Glow Plug High Side High Input
Any other takers?!?!?! anyone else think they are a mechanic?
Yeah, I be dere.
DIY King
Originally posted by noname
I will be there but I will b kinda late
cuz i get out of work at 5:30
hope everyone will still be there
