Windows rollinf down on their own
Ok this has happend to me twice now. I come home with the windows and sun roof closed only to find them open a few hours later has this happend to anyone else or am I and isolated insodent.
Re: Windows rollinf down on their own
I'm not sure if Honda does this, but some manufacturers/aftermarket remote starts will do that if certain buttons on the fob are pressed/held, or if the key is turned in the door lock a certain way. Do you keep your keys in your pocket? Try keeping them out of your pocket when you're at the house and see if it stops happening
Most people cause this as they are walking up to the car pushing the unlock button several times.
If you double tap and hold down the UNLOCK button on the fob, that rolls down the windows.
They may also roll down if you keep tapping the button too (I did not check this)
It's in the owners manual.
You cannot roll the windows up with the fob though.
You CAN stick the key in the door and hold it in the lock position to roll the windows up.
Its been raining almost all day to boot
