Mechanical Problems/Vehicle Issues & Fix-It If you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
2016 Civic EXT feathers while cruising
Old Jan 11, 2018
tempered's Avatar
tempered is an unknown quantity at this point
Best way to describe this issue is while in Drive on a flat road with cruise control set (happens without it too), the car feathers the gas. It won't keep a constant rpm to keep a constant speed, rpms will drop they will pick up, it will drop, rinse and repeat.
Has anyone experienced this before?
Old Jan 11, 2018
Re: 2016 Civic EXT feathers while cruising
"Vehicle surges at highway speed" is your complaint?
Go to your Honda dealership immediately!
There is a software update to address the issue.
sumncguy
Oct 14, 2016 07:10 PM
korthos
Sep 14, 2013 08:14 PM
Fudman
Jul 23, 2013 07:34 AM
jodave
Jan 21, 2004 12:50 PM
