Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
97 LX exhaust system nightmare!
Old Oct 10, 2012
PowWow's Avatar
PowWow is an unknown quantity at this point
I ordered replacement pipe/muffler for my LX on autopartswarehouse.com a
month ago because the exhaust pipe have rusted apart. I tried attaching the
replacement pipe but there's an 18 inch gap between the downpipe and the
replacement pipe. I have a stock ex catalytic converter because I thought that
the cat was what I needed but I recently found out that the lx model already has
the cat bolted on the manifold. I'm not so sure as what to do right now. Should I
order a cheap ebay test pipe or what? I need/want to fix this up ASAP!
Currently driving a 2004 Mitsubishi Endeavor and it's eating gas like crazy!
PS. I'm just an amateur trying to learn more/save money!
Old Oct 10, 2012
PowWow's Avatar
Re: 97 LX exhaust system nightmare!
Or should I invest in an ex exhaust manifold? Will that fit my lx?
Old Oct 10, 2012
gp356's Avatar
gp356 is an unknown quantity at this point
Does the exhaust have a 2 bolt or 3 bolt flange if it is 3 you received the ex exhaust were the cat is located after the exhaust manifold. Assuming you have the ex exhaust yes a ex manifold will work but you will need to relocate the lower o2 sensor to the location of the ex cat.
also when looking for a ex manifold the 96-98 will have the upper o2 sensor in the same location as your lx and the 99-00 you will have to relocate the upper o2 sensor as well down by the flange were the manifold connects to the cat.
Old Oct 10, 2012
PowWow's Avatar
So if I were to get an ex manifold, should I also get a new down pipe or would it be okay?
cukaracha
30
Jul 26, 2015 12:01 PM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
ZILLA
Jul 5, 2015 05:24 PM
Causemo
Jul 5, 2015 06:42 AM
