2002 HX coupe, MT.. looking for better MPG's
This car is bone stock other than a stock replacement clutch, new tires, new spark plugs, it has 146k miles, burns/leaks no oil, and a stock replacement air filter. I am replacing the #2 and #3 02 sensors this weekend, the car currently gets 40mpg's without the AC on and that is literally all hwy driving. I'm wanting to increase the MPG's so I have been thinking about a CAI with the AEM dry filter (from what I've read is the best for these cars). Any other recommendations? Car has to pass a state inspection with no sniff test. Car still has the factory HX wheels with stock sized tires.
Re: 2002 HX coupe, MT.. looking for better MPG's
Switch to the skinniest LRR tires that are the same circumference as the originals? (use a tire size calculator)
Make it more aerodynamic?
research:
ecomodder
hypermiling
research:
ecomodder
hypermiling
Lighten car will help, too.
Honestly, 40mpg with no AC is really good. I get ~32mpg mixed city/highway atm
I get far better mileage at 45-55 than I do at 75-85 (well maaaybe 90+ depending on traffic)
40MPG's is actually really good i see Your using a AEM (DRY) performance Filter
Good choice there, and you have changed spark plugs, not sure if Your 2002
is equipped with a (Mass Air Flow Sensor) or not? if it does? make sure its clean if
it hasn't been cleaned in a long while ( as in Years) take it off and use only Mass Air Flow
Sensor cleaner. comes in a spray can. take the sensor off and use some CRC
M.A.F.S cleaner on it (Let it dry for 15-20 minutes before You start Your engine.)
i did mine on my 2008 Civic DX and believe it or not picked up a slight increase
in mileage and Performance from just cleaning it...
