engine rpm
Old May 15, 2012
Kenstill04's Avatar
Kenstill04 is an unknown quantity at this point
engine rpm
Have recently purchased a 2001 Honda civic lx auto trans. All seems to run well but don't what is common for rpm at highway speeds rpm shows at 60 mph at 2200 to 2300 wondering what is normal it has 1.7 engine noise inside sounds like a very loud bumble bee anybody please let this old man know what should be the proper rpm or is that close thanks
Old May 15, 2012
Re: engine rpm
The RPM is about normal, you can't change its gearing anyway.
It's a small 4 cylinder. It has to make up for its lack of torque with higher RPM.
The noise?
I can't hear a darn thing from here but my TV set.
Could be anything.
Wheel bearing, choppy tire tread, exhaust, etc.
Have a pro give it a test drive for an opinion or an evaluation. Then you may need to do a little checking.
HTH
Old May 16, 2012
Kenstill04's Avatar
Re: engine rpm
Thank you for the info it was very helpful
beneditti
Jan 15, 2016 12:31 PM
Wild Cranker
May 19, 2015 06:10 PM
Ninetyatecivic
May 9, 2015 07:48 PM
dooner24
Apr 14, 2015 07:51 PM
TaiChi
Dec 17, 2001 09:09 PM
