Greddy EVO 2 exhaust rattle...any solution?
Old Dec 2, 2006
sitinduk's Avatar
sitinduk is an unknown quantity at this point
To all those w/ the Greddy EVO 2 catback, does your exhaust rattle against the underside of the chassis?
I have an LX, so I used to have it installed w/ a Tanabe extension pipe. The piping kept hitting the underside of the chassis below the shifter. I replaced the front exhaust hanger (rubber piece) w/ a stiffer one from Autozone. It helped alot, but not when it rained.
From what I understand, this is a common problem, especially in the rain (hot metal expanding). How can it be corrected? Have an exhaust shop bend the pipe, weld on another hanger near where it rattles?
Old Dec 2, 2006
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
that is so funny you ask, I have the exact same problems as you down to the t....I am embarrassed to drive in the rain, any help would be great! it sounds like I am dragging a port O potty around
Old Dec 2, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
a new hanger would seem to fix it, but i don't know, i have an magnaflow catback and have no issues with clearance, so i dunno...
Old Dec 3, 2006
VWR32Turbo's Avatar
VWR32Turbo is an unknown quantity at this point
was looking for poly bushings for my R32, this company has some universal exhaust hangers (cut to length) might help...
http://www.powerflex.co.uk/exhaust.asp
Old Dec 3, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
I took off the heat sheild that protects the chassis from the exhuast heat, dumb i know but hey no more rattle lol
Old Dec 3, 2006
sitinduk's Avatar
Mine acutually used to hit under where the shifter is located. The LX doesn't have a heat shield there.
You would think for a $500 dollar exhaust, they would of had this issue solved before it went into production.
Old Dec 3, 2006
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
i have the same problem too..mine rattle sometime and i still cant figure out where its rattling from..and it only rattle when i hit 2.5k rpm ...under or over will not...wier
Old Dec 3, 2006
D5cIvIc's Avatar
mine did it twice, i just had my exhaust shop rebend teh pipe. The heated it up a little and bent it a little. No more rattle. problem fixed. I own an EX though
Old Dec 3, 2006
tntomek's Avatar
tntomek is an unknown quantity at this point
Same issue with the rain. Had the rattle all around until i fastened the pipe to the chassis (via a metal-rubber-metal clamp). The location where i fastened it was about a foot and a half from the cat, the pipe didn't seem to be shaped to run 100% along the heat shield. Now it only rattles in the rain.
Side note: do you guys hate the exhaust sound at around 90-120kms/h? I have the stock EX cat. Would replacing it with a sound resonator help? Any other suggestions?
Old Dec 3, 2006
sitinduk's Avatar
Where did they bend the pipe...a little down stream of where it attaches to the cat? How much did they charge?
Any pics would be greatly appreciated.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jdh022764
18
Nov 3, 2015 06:44 AM
TheRiddicles
Sep 21, 2015 03:34 PM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
