Custom made Camshafts
Do u have a website to this guy?
i have researched a few of the "claims" myself with out any negative outcome. if you have info on who it was the post it up also on the situation. check my posts youll see the conversation between members here
i see no reason why this isnt a good package. he is well known and respected in the import world. he has been around for years with thousands of happy customers. if you do some research on other boards about his work i think you will be able to make the decision for yourself. its definately the cheapest route as far as an entire head package by far!!!!!!
as far as i know by looking at the specs its an aggressive cam. it has more lift than that crower stg 2. the 7thgen ecu is touchy, not many people have been sucessful with tuning it n/a. cams cause vaccum issues and such. he is claiming good idle and no tuning issues. with out EMS you will be limited to the rev limiter on the stock ecu. i definately believe that the ecu can learn how to control the cam. i have seen ecu's adjust for boost with the stock 2bar map. the injectors shouldnt need to be replaced either making that much easier for the ecu to adjust.
ya i think ur right it is a great package most of the time it almost 700.00 to get a head ported and his package is 1200.00 that a good deal considering u get new valves springs th hole works i will probaly do it i emailed him on how much just to grind a cam was so once i get a quote i will post it
Official Rattlesnake Hunter
This friday!!!
I gota do this in steps & stages,
as you have said over & over it
cost so damn much!
But I cant wait to see what happens
when I tune it with the VAFC2!
I installed my new tranny also!
Cant wait!
cost so damn much!
Cant wait!
Re: Custom made Camshafts
Ight I got a question for you guys....I'm trying to find at least stage 2 cams but been having really bad luck, because everything is for the A2 and not the A1. Now my question is can I put the A2 engine head on A1 Block or am I just going to have to do a full engine swap? And what modifications will I have to do to make this possible?
jdawgzcivic
17
Feb 1, 2020 04:16 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Bricoleur
Sep 9, 2015 12:23 PM
redcloud
Sep 7, 2015 01:45 PM
