Vavlez!!
Old Sep 19, 2005
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
Vavlez!!
I just thought of this....When you turn your car off, do your vavles in your combustion chamber ever stay open on one side or the other? Like for instance when the cam stops turning does it stop at a certain point or just wherever it wants to?! ITS MIND BOGGLING!
Old Sep 19, 2005
dirtySAMURAI's Avatar
I log in from time to time
vavles?
Old Sep 19, 2005
vavles?
yea! vavles, yo!
haha.. sorry.. couldnt help it..
Old Sep 20, 2005
AlienX's Avatar
AlienX will become famous soon enough
yes they would stay open, partly or not..some even full, just depends on when you stop the car.
Old Sep 20, 2005
ragingSPAM's Avatar
I just burnt my tongue
good question indeed...im gonna ask my autotech prof
Old Sep 23, 2005
vtecd17's Avatar
yea i know how to spell valves...anywayz isn't that kinda bad if your intake valve stays open, couldnt dust and other foreign materials get into your chamber ?
Old Sep 23, 2005
AlienX's Avatar
ur TB will be closed.. then your air filter would prevent that if your TB was open neway. The engine does intake dust and other foreign matter while your driving, it gets burned off, the stuffs too small to do ne damage.
Old Sep 23, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
u know whats sick to do with valves and sounds awesome, revv ur engine up around 5k rpm, then shut the car off while revving. im serious, this is cool
Old Sep 23, 2005
streetglower's Avatar
exactly. they stop where ever. now to put it in basic words, when you go to start the car, when the PCM recieves the correct signals from the cam and crank sensors to the position of the number 1 cylinder, the PCM will go ahead and start sending the correct signals to the correct ignition ignition coil which in turn will start the car. Everything has to be in the correct sequence for the car to start. Thus the reason why vehicles use sensors to determine the position of the cam and crank for proper fuel sequence and proper firing of the cylinders. If the PCM doesnt recieve any signal from those sensors, the PCM wont send any signals to the coils to start the car.
