HP Race Header Questions
Old Aug 8, 2005
midnightblueciv's Avatar
midnightblueciv is an unknown quantity at this point
ok i searched and couldnt really find an answer...i have an 03 ex 5 speed and was wondering if there were any fitment issues with the HP race header that comes with a hi flow cat...and i found one at true honda for 280 shipped but it was chrome...anyone have any experience with the chrome one...thanks any help is greatly appreciated
Old Aug 8, 2005
Karumba's Avatar
Boredom causes changes ;)
Well since I first went that header route I'll say you didn't search really good.. first off, Edward (Truehonda) gave a link to a DIY guide in one of his older posts.. in that post it explains some of the difficulties: http://www.7thgencivic.com/forums/sh...hp+race+header
Basically, you will probably have mounting issues which will either lead to a) decimating your motor mount to fit (not a great idea) or b) lifting your engine off its mount to install the header then reattaching everything (slightly longer procedure)
Hopefully that is all your issues with it .. as I assume it would be going onto an EM2 rather than an ES1 like myself
Old Aug 8, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
^ hmm...too much hassle tryin to instal a little header.
Old Aug 8, 2005
djmota's Avatar
its not a lttle header. its kinda big
chrome is the only way I have seen them supplied. the install is a pain but not that bad. You may have some rubbing/rattling against the front part of the subframe (some people have described this problem before. I have not run into it) . to fix it they grinded down on the sub frame a bit. < no it does not effect anything.
Old Aug 8, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
All that for what, 1-2 hp, and shiny metal in engine bay, save your looot
Old Aug 8, 2005
i pretty sure the race header has more then 1-2 hps...dont be a hater
Old Aug 8, 2005
Wizkid's Avatar
Wizkid is an unknown quantity at this point
I have the header installed. Yes, i does take longer to install than most do. But the gains from it are worth the hassle. Instead of cutting the mount as described in the DIY, I supported the front of the engine with a jack, then removed the mount. Then you have to fit test the header, and decide on what needs to be ground down. Keep in mind that you can raise the mount a bit to gain a little extra clearance, but not much. Once thats done, then pull the header thru, and support it while you bolt the mount back on. Then install the header. I got some slight vibration at first, so then I installed a set of Energy Suspension mount inserts, which stiffened the mount and added a little more clearance. It took me about 3 hours total to get the initial installation done.
Old Aug 8, 2005
is the cat on the header an actual high flow cat?
Old Aug 8, 2005
Wizkid's Avatar
it comes with what they call a "high flow cat". In actuallity, its only a resonator tube. As it says in the description of the product, for off-road use only. I installed the "cat", but didn't like the high pitched sound that was the product of it. So I ended up installing a modified stock cat to cut the sound, but still get good air flow. The sound is a very deep rumble with my Apexi N1 exhaust. You definetly notice an increase in throttle response and acceleration. IMHO, it was worth the trouble. Also, it does come with an O2 Simulator, but the directions are sketchy at best. I ended up getting a Casper Electronics (https://www.casperselectronics.com/M...ory_Code=honda) O2 simulator. Instead of cutting wires, it plugs into your stock connectors, getting rid of the headache of installing that.
Old Aug 8, 2005
yeah im just goin to buy an actual high flow cat...thanks for the help
Old Aug 8, 2005
djmota's Avatar
The motor mount inserts are what keeps mine from rattling also.
Old Aug 8, 2005
jackburton's Avatar
intake, headers, exhaust, and tunning <15hp
I am a realist, not a hater!
Old Aug 8, 2005
jttegx's Avatar
OMNES AD UNUM
race header = best bolted on mod for the d17 powerplant IMO. preferably the 4-2-1 design.
Old Aug 8, 2005
djmota's Avatar
agreed
Old Aug 8, 2005
nope hater
Old Aug 8, 2005
how much would u guesstimate that it would cost for a mechanic to put in the HP full race header in properly?
Old Aug 8, 2005
jackburton's Avatar
Unless your setting up a nitrous system header is a waste of money.
Think about it you can spend atleast a couple of g's on a N/A d17 and never reach the 150whp mark, and you can spend a couple of gs on a turbo system and have atleast 150whp. OR you can run nitrous, but that is really only for strait line so it is very limited, but your getting more bang for buck then N/A by far, but it is more for someone who goes to the track. I am not trying to hate on you, they do look nice, but you are not getting any real power out of them unless you spray nitrous or spend atleast a couple of grand for alot of other upgrades that are not bolt ons.
Old Aug 8, 2005
im pretty sure thats not what i asked...like i have the money to spend and thats what i want to do to MY car...i know its difficult but thats the route i wanna go...so if u dont want to answer my question then dont post anything
Old Aug 8, 2005
sorry but my goal for my car is to push it as far as it will go without spraying or forced induction regardless of how much it costs
Old Aug 9, 2005
jackburton's Avatar
All right, well you think you can spare some, cause im a little low of cash, if you just gonna throw it away.
It takes atleast 3-4 grand to get 150 whp N/A, and if you acomplish that i will give you my first born.
Why not go FI?
I know that nitrous is limited, but why not go with turbo?
If you are worried about daily driving and willing to spend so much money you could get the aem ems, and have her running like a champ.
Could not help my self
Old Aug 9, 2005
u will never understand
Old Aug 9, 2005
jackburton's Avatar
Try me, autocross, maybe?
Race class?
Pride of having something original, and rare?
Fathers last words were naturally aspirated?
Old Aug 9, 2005
amhtown01's Avatar
Race class?
H A T E R
In case you forgot what he said, i will post it for you again.
He said, "my goal for my car is to push it as far as it will go without spraying or forced induction."
I had so much to say to you jackass, but its not worth my time to talk to someone as hard headed as you are.
Old Aug 9, 2005
jackburton's Avatar
I am just curious why he does not want to turbo and why his goal is what it is.
I never called anybody any names, or anything like that.
What can't i understand, what you think your better than me?
I listed reasons one might want to go N/A on the d17 are these why your goal is what it is, c'mon enlighten me.
Old Aug 9, 2005
scizod's Avatar
scizod is an unknown quantity at this point
sorry to cut in on your thread....I put on the HP race header and it was sitting directly on my sub-frame so I had them remove it. Now I hear about these energy motor mounts that prevent that from happening. Where do I get these motor mounts and how hard are they to install?
Old Aug 9, 2005
i just believe that going the forced induction route is unreliable and IN MY OPINION "cutting corners"
Old Aug 10, 2005
jackburton's Avatar
With the aem ems, you can have a perfectly reliable car, just as any highpower N/A
Sure it is cheap and inexpensive, but in the end you will need a turbo on a d17 to make any considerable power anyway. No reason not to start with one on low boost and then build internals, progressivly uping boost. Cutting corners is sometimes a good way to go cause there is alot of value in it, cheeap and inexpensive is not always bad IMO. I do not understand why you would want something slower and more expensive VS. cheaper faster. With 180 whp turbo, head studs, and aem ems d17 you will be just or even more reliable as <150whp N/A d17.
Old Aug 10, 2005
jackburton's Avatar
Wait a minute, you said money was no object and you would spend as much money as possible to get fast N/A. You then say you do not want turbo because it is easy and cheap, but you could have expensive turbo kit if you wanted?
So the only reason i can think of is the fact that you wanna do something challenging, and making the17 a N/A pwerhouse is because it is near the impossible mark, so you kinda like a rebel.
Old Aug 10, 2005
djmota's Avatar
jeez just let it go man. He has a different opinion then you. The thread and question was about the HP header, not What do YOU want me to do?
Old Aug 10, 2005
djmota's Avatar
You can get the inserts from robear racing or other vendors. The front is very easy to put in, the rear is a pain.
