Muffler Size (already searched)
Old Jun 4, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
What size Muffler inlet would be a direct fit onto the stock piping? Please only reply if your absolutely sure, i dont want to buy the wrong size and have to modify it. i need to get rid of that coffee can honda has for a muffler. thanks guys
Old Jun 4, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
why dont you go measure your piping?
Old Jun 4, 2005
i just did, i think its about 1.5 to 1.75, now im trying to get that stupid rusted *** bolt off,, hmmm, wonder if a heat gun would help
Old Jun 4, 2005
i dont know if i want to mess around with a heat gun around there, isnt that close to the gas tank? oh well ill just keep spraying with wd40 and hope it budges.. i got the first one off easy
Old Jun 4, 2005
Xenin's Avatar
i think someone mentioned stock piping is 1-5/8"
Old Jun 4, 2005
Got the bolt off, just tough without power tools.. hmm 1 5/8? because i just basically want to Cut off the stock muffler and use the same piping and i probably wont even weld the muffler.. i called monro and asked how much to weld a muffler to the pipe he was like 85$,, im like hell no.. ill probably just use a couple clamps and make them really tight..
So what do you guys think size inlet i should get if im using clamps and not gonna weld the muffler to the pipe. So the pipe will either have to slide in or slide on top. hmm comments?
Old Jun 4, 2005
Well i guess it would be to small to slide in, ill get 1.75 and if its to big i guess ill buy one of those tools to expand the pipe.
Old Jun 4, 2005
Xenin's Avatar
i think it was cheaper for my buddy to get his tanabe catback onto his RSX, and i live in Canada. just call around.
cukaracha
Aug 27, 2015 02:02 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
