cheap or free mods/stuff to do
Old May 17, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
ok i was trying to see what else i can do
i have done so far,
Removed Intake resonator box and connected tube to intake box
Changed oil with mobil 1 and pureone filter
Removed Jack, spare, trunk board and trunk carpet
i know i can also tighten my throttle cable, but imma newbie and dont know how to and there are no pics in the DIY! oh well later
Old May 17, 2005
Peasey's Avatar
Peasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to behold
and why would you do that...i guess the removal of carpet makes you run a 17.8 instead of 17.9
as for Cheap DIY's..why not black out your headlights....and you can get some neuspeed lowering springs for pretty cheap...lowering the car is the best way to make your car LOOK fast
Old May 17, 2005
lol ok forget it, i just mean jack and spare and trunk board, that is some weight loss
Old May 17, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
throttle body coolant bypass- do a search there is massive lists that people have put up before
Old May 17, 2005
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
actually im selling my Neuspeed race springs. 2.25 front 2.0 back. I only drove on them for about 2k miles, I got a good deal on SS, so I dont need these. I bought for 125 from pete. PM if you interested.
Oh Neuspeed ownzz in suspension for our cars.
Old May 18, 2005
flqu05's Avatar
flqu05 is an unknown quantity at this point
tHE ONLY SENSIBLE MOD TO MAKE TO OUR CAR IS REDUCE WEIGHT. MOST EVERYTHING ELSE IS A WASTE.
Old May 18, 2005
reefer_bob's Avatar
reefer_bob is an unknown quantity at this point
Wow... that was rather informative...
So in-expensive springs do nothing? Upgraded Swaybars (RSX) do nothing? I/H/E does nothing? NOS?
While granted yes, reducing weight helps considerably... but how much can you really do, and still have a daily driver?
Is losing 100 lbs of weight, gonna make you quicker in an Auto-X course than a set of springs? Make ya faster down the strip than I/H/E?
Last I checked, the only way to reduce weight, freely, was to start ripping out spare tire, jack, seats, carpet, speakers, headliner, headunit... but then you've got a gutted stock civic which would suck.
Now if you did meaningful lightening mods.... lightweight battery, light weight racing seats, light weight wheels, header (vs. heavy cast iron manifold), test pipe (inplace of a heavy Cat-Converter), light weight titanium exhaust... Now we're talkin!
I guess the only cheap perf. upgrade you could do, would be to gut the cat, or run a test pipe... you'll throw a CEL, but it'll make you go faster, cheaply!
Old May 18, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
remove your power steering, take out your a/c (if you can live without it) and everything else that everyone else listed.
Old May 18, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Buddy club race spec condenser. I swear by it becuase my mpg has increased by 3 mpg.
Old May 18, 2005
reefer_bob's Avatar
Indeed, I forgot about these! PS is decent, I can't live with out my AC.
Although when the AC clutch isn't engaged, the parasitic losses are quite low. How much does the stock AC unit and condenser weigh?
Old May 18, 2005
SevenCyrus's Avatar
This is stupid, weight reduction...to a d17...for drag.
Old May 18, 2005
pon55's Avatar
I'de say, take out the brakes, they only slow you down!
Old May 18, 2005
yes
I fcking love it!
Old May 18, 2005
turboengnr's Avatar
DONT PANIC
Look at my mod list.....
still full interior, still PS and A/C, still daily driven about 30 miles/day
Old May 18, 2005
Graphicdude's Avatar
Creative Mind Extraodinare
Graphicdude will become famous soon enoughGraphicdude will become famous soon enough
you did this to your D17 engine? What are you running for HP and Torque now?
Old May 19, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
my cousin did this a few years ago on his beater Corolla, just opened up the stock airbox and drive. It sounded like he had an aftermarket intake. Didnt do this for long though... replaced with an aftermarket 1.
Old May 19, 2005
2K1Civic17"Gabe's Avatar
instead of tightening the cable, look under your gas pedal (inside the car), there is a black piece of plastic that stops the pedal when its allt he way down. There is a bolt or two holding it on, just take that piece off, and you hit WOT. Its more reliable, and it is the perfect amount of extra throttle to hit WOT, and not break something. DO NOT TIGHTEN the cable. Cars with extra slack have the piece under the pedal, so always look there first.
Old May 19, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
There is a diference between WOT and the slack in your cable. They have two different effects. Removing the plastic thing under the pedal is not going improve anything if your already getting WOT.
Old May 19, 2005
You dont reach WOT, because there is slack in the cable. If you can press the pedal down more, you get more throttle, giving you WOT. I understand its more jumpy with the tighter cable, but you risk tightening it too much and breaking something. This way, you get the same throttle as tightening, but in a safer way. Do you understand??
Old May 19, 2005
dariusld's Avatar
I have slack in my cable, and reach WOT. Practically everyone that has slack in their cable reaches WOT. I'm assuming people take the slack out of the cable for faster response. Pressing down the pedal doesn't give you WOT, more throttle doesn't give you WOT, WOT gives you WOT
Old May 19, 2005
hmmm.. so it would be an ok idea to remove that black thing under the pedal?
Old May 19, 2005
i couldnt get the bolt off of the black thing.. so i just ripped it off lol.. kinda like i did to the resonator when i couldnt get that last clip off.. if all else fail use wire cutters and tear it off!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
SuperNova18
15
Mar 12, 2017 03:11 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
krazykoncepts
Jul 14, 2015 01:55 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
