kkamikaze 01-03 lx header for 04 lx?? will it fit
Old Mar 8, 2005
scooterman1's Avatar
scooterman1 is an unknown quantity at this point
kamikaze 01-03 lx header for 04 lx?? will it fit.. anybody no?
Old Mar 9, 2005
R1Style's Avatar
yes it will fit
Old Mar 9, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
ya most parts are listed as 01-03, i have an 04 lx and im thinking about getting the kamikaze, where did you see it?
Old Mar 9, 2005
i saw a link by speedster that led me to the header.. this is apparently a pretty sweet header.. im gettin it now.. thanks for the help guys!
Old Mar 9, 2005
ill post the link asap
Old Mar 9, 2005
http://www.mmrusa.com/kamcivic.htm.. this is the link for that header i was talkin bout.. im gonna buy it this week.. but i need some help.. should i go with the nickel header or the ceramic.. which is better and gives better performance? any1 no?
Old Mar 9, 2005
ajhdragon's Avatar
7thgens official a$$hole
ceramic
Old Mar 9, 2005
i heard ceramic too... but doesnt it like wear out more.. like turns red after a while and is weak.. i mean honestly.. what is the hp difference between nickel and ceramic?
Old Mar 9, 2005
R1Style's Avatar
there is no hp difference. It's just a different finish...
Old Mar 9, 2005
different finish as in what? basically there is no difference in performance between nickel and ceramic?
Old Mar 9, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
I got the nickel and it is hot as hell. Radiates a lot of heat right around my intake. The cereamic is suppost to keep the heat out of your engine bay and keep it inside the header. The only reason I didn't get the ceramic was I heard it cracks over time. Looking back though I would have went with the ceramic and taken my chances.
Old Mar 9, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
What about the chromed ones?
Old Mar 9, 2005
scatman's Avatar
Still in the game...
Originally Posted by R1Style
yes it will fit
...+1...christ you n00b.
Old Mar 10, 2005
if a header radiates alot of heat.. is that really bad??? and by the way.. redline how do u like the nickel header.. did it give u alot of performance and sound??
Old Mar 10, 2005
Redline04's Avatar
It's bad for me cause I have a AEM V2 intake sitting very close by sucking in all that hot air, which causes lower HP. I also overtorqued the top two bolts(peice of **** torque wrench) and snapped them and I beleive some hot air is ecaping do to that as well. Something I need to fix as soon as I get back. Other than the heat issue it seems to be fine. I installed the header and exhaust at the same time, plus I'm running no cat. It's been so long(6 or 7 mo), but I'm pretty sure there was a gain. I ran 15.7 with I/H/E my weight reduction and the power steering pulley belt off on stock 14's. with around 22psi. Bone stock I ran 17.0. So I'd say I shaved .3 due to improved driving skills/60ft and a full second from the combination of those mods.
If you want looks get the chrome, cause the nickel turns into this rainbowish/dull finnish.
Get the caspers O2 sim. Might be pricey at $80 to some people, but it is so easy a monkey could do it. Plug n Play saves time,looks clean and you could always go back to stock if needed, no splicing.
Old Mar 10, 2005
yeah i got the aem v2 intake as well... so tell me what header i should get.. the kind that would give me the best performance..
Old Mar 10, 2005
on top of that, i also got a full catback exhaust system (magnaflow) with the v2 intake.. and those 2 mods seem to bond very well haha.. so will this header make an even bigger difference since it would be running with a full catback exhaust system?
Old Mar 10, 2005
Redline04's Avatar
The ceremic would be the best performance wise to my knowlege. I can't say how much it alone will help because I installed my exhaust at the same time, but have you taken a look at the stock header. The tubes are like pancake thin compared to the kamakaze. Less restriction = better flow which = more power.
Old Mar 10, 2005
so overall ceramic header is the way to go.. b/c of performance and quality???
Old Mar 14, 2005
Calidan's Avatar
Calidan is an unknown quantity at this point
Yea, I have kamikaze headers on my 04 lx, it fit good, no need to even shave the alt. mount, its definently worth it. Oh, and sorry guys, no matter what, an intake is an intake regardless, its just a pipe with a filter, there is no serious difference, so quit wasting your time caring about it. Peace.
Old Mar 16, 2005
Smizay's Avatar
Smizay is an unknown quantity at this point
YOU guys are ****in great!!! i have been looking for headers for my car... i thought they didnt make any for LX civics. wow mad props to you guys.
Old Mar 16, 2005
Smizay's Avatar
is black just as good
Old Mar 17, 2005
Smizay's Avatar
will a heat sheild for my V2 help any? and when i get headers and catback on my 03 civic will i lose my cat also? ok thanks
Old Mar 17, 2005
kornsined's Avatar
a little but it's still sucking air fairly close to the engine. as for a header i think the HP racing, kamikaze, OBX, and megan header are all the same. so just pic the cheapest. although i'm not sure if all these companies make one for the LX.
Old Mar 17, 2005
Smizay's Avatar
Does anyone know if youll lose your stock catalyic converter when you add a full exhaust system and headers on a 2003 civic lx?
Old Mar 17, 2005
kornsined's Avatar
yeah i think so since your cat is in the header.
Old Mar 18, 2005
Smizay's Avatar
Can i bride the guys to pass smog???? hahaha
Old Mar 18, 2005
Smizay's Avatar
oh and will i need a new o2 sensor with headers and catback??
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Biggunschad
Sep 11, 2015 04:06 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
