Headers for 04 LX civic
Old Jan 20, 2005
Method4's Avatar
Method4 is an unknown quantity at this point
Anybody know where i can find a set of headers for my car??
Old Jan 20, 2005
streetglower's Avatar
At a store
Old Jan 20, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
A number of companies makes headers for '01-05 vics that would be compatible with your car.
Old Jan 20, 2005
Method4's Avatar
can yall give me a link?, i have searched all over.
Old Jan 21, 2005
vai2iant's Avatar
vai2iant is an unknown quantity at this point
eBay?
Old Jan 21, 2005
Method4's Avatar
yup, any other places??? i wana buy new
Old Jan 21, 2005
Method4's Avatar
alll i can find is headers for the EX why want it work????
Old Jan 21, 2005
I don't know for sure, but the EX has the VTEC engine and the bolt pattern (in terms of where the headers go) may be different on an EX engine then the LX engine.
Old Jan 21, 2005
Good lx header is made by kamikaze from www.bigjoshracing.com, however you should know that replacing the lx header will remove the cat (which is part of the stock header). So unless you don't care about passing emissions, I would look at a different mod or change to an EX exahust system so you can use the header for that. On the ex, the cat is located after the header and downpipe.
Old Jan 21, 2005
Do you know if the bolt patterns are the same on an LX and a EX?
Old Jan 21, 2005
Well yea, the top bolt pattern is the same, which is how members have switched to an EX exhaust system.
For the LX
For the EX
Old Jan 21, 2005
For the LX
For the EX
Dude...how do ya get these awesome factory pics?
Old Jan 21, 2005
hondaautomotiveparts.com
Old Jan 21, 2005
Your the man! Rep points for you!
Old Jan 21, 2005
Method4's Avatar
so a ex header would work?? i would just loose my cat?
Old Jan 21, 2005
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
http://www.whitelineperformance.com/...e.php?cat=1785
link ex ones just have to mod your lx pipes
Old Jan 21, 2005
the ex header will fit, but you need to change the rest of the exhaust to match. Otherwise get the lx kamikaze header and lose your cat if it's not a big deal. You'll feel a difference.
Old Jan 21, 2005
He'll feel a difference, but wont be smog legal and his check engine light will stay on.
Old Jan 21, 2005
Unless he gets an 02 sim, then engine light goes back off.
Old Jan 21, 2005
Are you sure? Based on my experience, the check engine light will stay on until either: (1) you disconnect the battery or (2) you go to the dealership and have them reset it. The problem is it will come back on. There are two oxygen sensors in our exhaust system, without the Cat, at least one of the two sensors will set off the check engine light.
Old Jan 21, 2005
yes that is what the 02 sim is for. The sensor that gets removed is ONLY required for telling the ecu that the cat is working. It has no effect on performance. An 02 sim will fool the ecu into thinking everything is a-okay with that sensor and fool it by sending the voltage signal to say the cat is working. So you hook up the 02 sim, reset the battery, and the light stays off.
Old Jan 22, 2005
Method4's Avatar
what do you mean, change up the whole exhasut?
and does that lx kamikaze header come with a cat on it?
Old Jan 22, 2005
IronFist's Avatar
Header. Singular. You don't get a "set of headers" for an I4.
But if you do get headers, and you have an EX, see the DIY link in my sig for help installing.
edit - I can't read the title of this thread. You have an LX. Nevermind.
Old Jan 22, 2005
Method4's Avatar
i have a LX, what i wana know is what all would i have to do if i got a EX header, would i loose my cat? and would i have to make any more changes?
and does that LX model header from Kamikazi come with a cat?
Old Jan 22, 2005
lx kamikaze does not come with a cat.
if you change to an ex header, you need the ex downpipe and cat, then I think you can just buy a catback exhaust for the ex (or find a stock ex exhaust). You're basically swapping the entire exhaust piping I think.
Old Jan 22, 2005
Method4's Avatar
ok i see, i allready have a pipe(axel back) i was wanting to get a (ex)header. and have 2.5 inch exhaust ran, what would i have to buy to still have a cat? im still just a bit confused (sorry)
Old Jan 22, 2005
the exhaust you have now will have to be modified to fit an ex header and ex cat. Refer to those pics I posted.
If you have an EX, the cat is at the bottom of the car after the header and downpipe. On the lx, the cat is actually built into the header. Replacing the header on an ex is a simple swap. Replacing the lx header is also easy, but aftermarket headers don't come with a cat like the stock one does. If you convert your lx exhaust to an ex exhaust, you can buy an ex header and all the other components of the ex including the cat, which will now be under the car. Either way, it will be better than what you have stock. Your current exhaust (custom?) will have to be changed if you do decide to run an ex header and downpipe with cat. lx and ex have different exhaust systems.
Old Jan 22, 2005
cubanmike26's Avatar
Gearbox, but what about if there's something wrong with the car later on...say the transmission, or some type of engine problem...Would the MIL light still come on after installing the O2 sim. if a new problem arises? Is the O2 sim. directly and only related to the cat.?
Old Jan 22, 2005
yes, the 02 sim is designed to bypass the sensor that says the cat is working. It won't affect anything else. You can try by pulling out the intake air temp plug and see if the cel comes on. I'm sure it would.
Old Jan 22, 2005
Cool, thanks.
