Header Help
Old Nov 25, 2001
JeffSpeed21's Avatar
JeffSpeed21 is an unknown quantity at this point
Header Help
I recieved my 4-1 ceramic header and i cant figer out how to get the 2 spring bolts out from the lower mount. Did u go under the car to take the bolts out or did u just take the nuts out from the top.
Old Nov 25, 2001
civicbluestreak's Avatar
civicbluestreak is an unknown quantity at this point
hey whats up
did you bust your knuckles trying to get the two nuts off from the top?? i did too till i found out there welded on. you need to get under the car and take the two bolts out that way. i had to use an air gun but once i did it was a snap. if its the dc sports header that i have you will enjoy the added low end torque. good luck.[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]and when you get done with that enjoy one of these[IMG]i/expressions/beer_yum.gif[/IMG]
Old Nov 25, 2001
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
i guess you could do it from the top but the way its supposed to be done is from the bottom, taking the bolt out slowly relieving the pressure off the spring instead of taking just the top nuts off and and having the bolt and spring shoot off.......goodluck, hope this helps
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
