how light is your flywheel?
Old Jun 17, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
mine isnt much
a little over 5lbs
Old Jun 17, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
That's pretty damn light. Good luck daily driving.
Old Jun 17, 2004
AR's Avatar
AR
e-married to daydreamer
oooooo sweet
Old Jun 17, 2004
CivicsRdBest's Avatar
How heavy is stock?
That's my answer to the question...
Old Jun 17, 2004
WannaBFast's Avatar
ill find out in a few weeks when i change my clutch
Old Jun 17, 2004
01civicUP's Avatar
01civicUP is an unknown quantity at this point
ya at fidanza they say it weights 7lbs. damn and take only like 15hp to make it spin. unlike the stock which they said can take up to 40hp. but they didnt say how much on the civics. but ya. how much did you pay for it? they didnt give a price. thanks
Old Jun 17, 2004
WannaBFast's Avatar
it depends on the vendor you get it from, but i paid $190 for it...
Old Jun 17, 2004
acjones20's Avatar
acjones20 is an unknown quantity at this point
too light and you're gonna stall like a biotch
Old Jun 17, 2004
WannaBFast's Avatar
hey.. i never said i wasnt gonna have a hard time readjusting..
Old Jun 17, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
what's a flywheel for?? is it worth getting?? if so i want one too.
Old Jun 17, 2004
blouisgod's Avatar
Life Begins > 6800rpms
9lbs and under is for race use and boasts shorter life span but faster revs. 12-13lbs. is recommended for street. I think the stocker is like 17-18lbs, maybe 20.
Old Jun 17, 2004
WannaBFast's Avatar
fast revs is an understatement... but it reduces the rotational mass that the engine has to constantly turn, so less mass = less resistance
Old Jun 17, 2004
WannaBFast's Avatar
if you notice the gear on the outside it is used to crank the motor.. the starter goes to the and turns the flywheel... it mates with the clutch
Old Jun 17, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
it takes a 500 hp motor to properly use an 8 pound flywheel. your fly is 7? ... have fun getting up hills
Old Jun 17, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Originally Posted by CivicsRdBest
How heavy is stock?
I weighed my stock ones to 24Lbs...
Old Jun 18, 2004
acidbaby's Avatar
The Beez Kneez
whats up with all the haters on this thread? ....ohoh good luck this that blahblah blah. damn man stfu!
btw props on the new mod bro! looking forward to here your review
Old Jun 18, 2004
WannaBFast's Avatar
the point to a lighter flywheel is to take advantage of underpowered engines...
i think you are thinking of something else
i didnt know the stock flywheel was that heavy.. i thought it was like 20lbs
Old Jun 21, 2004
WannaBFast's Avatar
ok.. clutch is installed, the stock flywheel weighs 18lbs
it revs up much faster now, and still seems drivable, the ACT heavy duty pressure plate
the main difference ive noticed was that the clutch was much harder to engage, and i have to press it to the floor to shift smoothly, its gonna take a little getting used to
but, I LIKE IT
Old Jun 21, 2004
djmota's Avatar
cool thanks for the update, keep us posted on drivability/stalling ect. with the light flywheel.
Old Jun 21, 2004
WannaBFast's Avatar
ive only stalled once.. and that was the first time i moved my car...
it feels like an older car with a cable clutch, its still nice since theres hardly any lag in the powerband when im cornering, well when i would be downshifting through the gears, it usually bogs down for a second, but it is tending to break loose in corners
BTW, i got an ACT street disk with that pressure plate, its not a harsh engagement, but with the heavy duty pressure plate, you cant drive your civic like you used to, its no longer soft clutch, so you are gonna get your left leg pumped up before you know it
Old Jun 21, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
uh yeah thx 4 info, buddy! if your flywheel is too light, then you lose power ... and a 7 pound fly is too light for anything less than a fully built turbo. emphasis on fully.
Old Jun 21, 2004
WannaBFast's Avatar
it seems fine for me... i dont see what the big deal is... i think the rule of thumb is dont go more than 60% of the original weight, so 7lbs fairly reasonable
the clutch is harder to engage but its nothing that cant be dealt with
Old Jun 22, 2004
WannaBFast's Avatar
well how is that different from getting ligher pulley's or wheels?
its NOT, the only downside to having this light of a flywheel is how quickly it drops in rpms when not on the gas, BUT its still drivable, and predictable
and it is only 60% lighter than the stock flywheel
you should not jump to conclusions until you tried it, ive tried it, and its not as bad as ppl say it would be, those 8lbs flywheels on those high powered machines depends on the motor, for example, a mazda kl03 flywheel wieghs 23lbs fidanza has a 9lbs flywheel, 60% of the wieght of the stock and some would argue that it is too light for that motor, ours wieghs 18lbs, the fidanza flywheel i have is 7lbs, which is 60%, a drag motor would probablly have an 8 or 9lbs flywheel since its a v8
now having a fully built turbo has nothing to do with reducing the rotational masses of moving components in the motor or other parts of the car, it just makes it easier to move the crankshaft, its the same effect as taking 200lbs off of your car
Old Jun 23, 2004
usafstud's Avatar
i see u got the "h1" model
so it does work on our car correctly? since on fidanza's website, its for a 1.6L sohc.
thanks
Old Jun 23, 2004
WannaBFast's Avatar
yes all the clutches for the d series are all the same since like 95 i guess, the fidanza part number is 191161
Old Jun 23, 2004
abmerop18's Avatar
Jam out with your clam out.
but, I LIKE IT
ya thats how my ACT clutch is. i like it alot. you feel more in control of it when the heavier clutch and it is alot more responsive. i defeniatly give it a
Old Jun 27, 2004
Crackhead79's Avatar
You ahd to of weighed that thing with vthe clutch and pressure plate on, cause wow, thats too heavy, I thought we were at 13-15lbs but as long as we stay within 60% weight of the stock we should not have problems, I still want the 6lber though lol
Old Jun 27, 2004
I asked this on another flywheel thread but just needed to know before I get this fly too--as far as the reduced mass which does help us revv faster and at lower speeds and gain speed faster due to the reduced mass, what about at like 90 mph? Will the reduced weight make it revv way higher than the normal 4500RPMs I normally get or will it actually get lower RPMs because of the less restriction? See I thought that stock weight is what kept it slowed down at those higher speeds???? Need advice pronto---Thanks ~Stevo
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Vaguexo
Jun 13, 2015 04:11 AM
Supramk3
Jun 11, 2015 11:13 AM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
