V-tech head
Old Jul 6, 2003
BlackCiv2002's Avatar
BlackCiv2002 is an unknown quantity at this point
V-tech head
ok i hava a 2002 civic lx and i want to get a v-tech head would it fit and anyone no where i can get one thanks
Old Jul 6, 2003
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
First off its VTEC. you can probobly find one in a junkyard or check out the for sale forum. Vtec on the d17 is too overated. IMO
Old Jul 6, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
dont bother, it's not worth the $$. It's not exactly a slap it on deal, and you most likely wont be getting as much HP as an EX.
Old Jul 7, 2003
cosmo's Avatar
cosmo is an unknown quantity at this point
If you want around the same power you'd need the pistons too, or if you want to go the N/A (Natuarally Aspirated--no boost) route just go to your dealership and get the Honda Civic GX (Natural Gas) pistons and they'll bump your compression up, but then you'll need alot of other things too, there's a thread on that if you want more info on that route-girl who did Honda GX piston swap You'll need the exauhst from one too or an aftermarket header and new piping from the header back (no cat would be the way to go depending on your local emmision laws). Umm, all else that I can think of is a new ECU and wiring correct me if I'm wrong and if I forgot anything.....Hope that helps!!
Old Jul 7, 2003
HondaLuver's Avatar
Its a celebration bitches!
haha v-tech,
don't both with vtec, you should be investing your money on some K20A i-vtec
Old Jul 7, 2003
CarbonFly's Avatar
Old Jul 7, 2003
MadWheel's Avatar
Premium Boosted Member
Yeah man, if you really want one, hit up a junk yard. It's a lot of money to gain a few horse. Why not boost? Go to the forced induction forum, there's some bang for your buck. You would need an EX exhaust as well, along with some good compression if you want to come close to the whopping 127hp. I reccomend saving a little bit more and buying nitrous/boost/swap/ or a built engine (Better off building up a swap). V-tech is a phone company, VTEC is what Honda uses.
Old Jul 7, 2003
gotti's Avatar
eye want der vtech headz mans
Old Jul 7, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
You can probably find the whole engine used for $500-$700. It's not exactly in high demand. Then sell your old one for around $500. If you shop around for the new engine and get good money for your old one, you could almost break even. Then all you have to really worry about is the labor for doing the swap.
However, why bother? getting VTEC in your engine bay isn't going to turn your car into a rocket. If you want to add power there are better ways.
Old Jul 7, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
VTECH is a damn phone!!
Heh heh..
Anyways, yeah, like everyone else has said, invest your money in something else. I suggest buying a good intake, exhaust, clutch and flywheel. Then some nice tires, a little weight reduction, and you're set. This way you're putting as much to the wheels as possible. Plus, if you figure how much it costs to put all these things in your car, it comes out to the same price (roughly) as if you were just gonna put the VTEC head on your LX.
Old Jul 7, 2003
Green Civic's Avatar
Save your money. No point for 10 hp. Full engine swap or be happy with original engine. Vtec is not as powerful in the d17a2 as in other hondas or acuras.
Old Jul 7, 2003
Reading your post raised a question for me... VTEC is not as powerful... WHY? Could it be because the cam profile is less aggressive than in other Honda engines? If that is the case maybe a "Race" cam could yield decent results. Maybe someone more familiar with the design could shed light on this.
Old Jul 8, 2003
wonderz's Avatar
wonderz is on a distinguished road
perhaps dual cam with a larger engine block will help vtec SHINE
p.s. anyone got it? shed light on this...shiny vtec
Old Jul 8, 2003
Most other hondas and acuras have dohc instead of sohc. So two over hand cams will pull vtec a lot better than a single over hand cam. Of course a racing or proformance cam will perform better than a stock cam, but a single cam can only do so much to performance.
Old Jul 8, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
The advantage of a DOHC over a SOHC is that you can tune the timing of the intake valves with respect to the exhaust valves (the overlap) by just adjusting the CAM gears. With a SOHC to make such changes, you would need a new CAM.
You should be able to have a SOHC achieve the same results for a given application, if you have good R&D. You just loose the flexibility of changing the overlap with additional mods.
Bottom line: a SOHC can perform as well as a DOHC, it just depends on the R&D that goes into it.
Old Jul 8, 2003
Yes, that is correct. Thank you.
7thgensurvivor
Aug 26, 2015 06:17 PM
hoofboy
Jul 17, 2015 04:27 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
Ccoop87
Jul 9, 2015 03:26 PM
